Vancouver Impreza Club
Go Back   NASIOC > NASIOC Chapters > Vancouver Impreza Club Forum -- VIC > VIC Vendor Classifieds
Closed Thread
Old 07-10-2008, 12:32 PM   #1
dalesalignment&brake
Vendor Sales Rating: (47)
Member#: 173316
'13 BRZ
Default RCE Tarmac Zero now available.
Built by KW Suspension in Germany to our specs, these use the same high quality stainless steel corrosion resistant construction as our RCE T2s.
The difference here is our Tarmac Zeroes have preset damping that maximizes both performance and ride quality. This allows the end user to just put them on and drive without worrying about playing with too many adjustments. It also keeps them more affordable. Ride height is still adjustable of course.
Linear spring rates:
400 lbs/in front
340 lbs/in rear
Front and rear helper springs included. Can be used with camber plates or Group N strut top mounts.
$1750+shipping
Next is our Racecomp Engineering Swaybars. We didn't try to reinvent the wheel here, just provide another option for GD Impreza owners looking for a swaybar set that will work well with stock springs, lowering springs, or coilovers.
Specifications:
25.5mm physical diameter
4142 Chrome Moly
Heat treated and cold finished.
Ends are hot forged on a 125 ton press.
Front and rear adjustable.
Washer tabs on front and rear to prevent walking
Finally color will probably be black.
The settings for the front are 25.5 and 28.5mm.
Rear are 25.5, 27.0 and 28.5mm. So you could run these and not have to go to a bar that is actually 27mm thick.
PM for pricing and availability.
dalesalignment&brake is offline
Old 07-10-2008, 03:29 PM   #2
semaj
I'm sorry for apologizing
Moderatour
Member Sales Rating: (46)
Member#: 113533
2006 Pathfinder
Off Road
Wow those look amazing Jason!
Wish I had money
semaj is offline
Old 07-25-2008, 11:35 PM   #3
Member#: 173316
'13 BRZ
Bump for the weekend
Old 07-27-2008, 10:23 PM   #4
Chp_Stix
Member Sales Rating: (20)
Member#: 95195
1974 Rat Rod Bug
back and white
hey can you do these for me with a set of camber plates for front and rear as a set up? I am thinking I need to upgrade my coilovers I am not too happy with my current ones... You can either PM me or we can talk when I come by to drop off my wheels later this week. Also how would these compare to my megans? I just want a little more ride comfort
Chp_Stix is offline
Closed Thread
RCE Tarmac Zeros in stock dalesalignment&brake VIC Vendor Classifieds 1 12-02-2008 05:08 PM
RCE Tarmac Zero in stock dalesalignment&brake Canada Region Vendor Classifieds 0 11-20-2008 04:19 PM
RCE Tarmac Zero avaialble. dalesalignment&brake VIC Vendor Classifieds 0 08-20-2008 02:12 PM
NEW Suspension parts from Racecomp Engineering! RCE Tarmac Zeroes and RCE Swaybars!!! RaceComp Engineering Suspension/Brakes/Handling 10 05-27-2008 10:25 PM
