Old 03-05-2002, 07:32 PM   #1
WRxednEffect
Member#: 13105
Default can a boost leak cause high egts?
can it? When my turbo spools its really really loud. sounds like a boost leak. but it does hold boost.
WRxednEffect is offline   Reply With Quote
Old 03-05-2002, 07:39 PM   #2
TerenceT
Member#: 9510
04 FX35
Pearl White
boost leak means it can't hold boost
doesn't high egt means it's lean? if it's rich, the fuel would cool the egt down
TerenceT is offline   Reply With Quote
Old 03-05-2002, 07:40 PM   #3
shabby
Member#: 2682
93 Eagle Talon AWD
If you have a boost leak you'll run rich, so your egt's will drop.
Of course you could be running so rich that the fuel will ignite in the manifold and will heat up the probe, you'll know when this is happening when you see a 10 foot flame in your rearview mirror
shabby is offline   Reply With Quote
Old 03-06-2002, 11:22 AM   #4
WizardBlackWRX
Member#: 14979
If you have a boost leak, your controller will make the turbo work twice as hard to hit full boost. This will make it run inefficiently and spit out very hot air. Even if you are dumping fuel, it can get bad enough that that will not be enough. Plus, the fuel is cleaning the oil off the cylinder walls and that is not good. Go around and check all your fittings and get a leak tester if you can. A fab shob should charge you very little to make it and a service center should charge you very little to test with it.
WizardBlackWRX is offline   Reply With Quote
Can a boost leak cause a knock? Deserted1 Engine Management & Tuning 2 04-18-2009 01:02 PM
Cold Idle issue causing high EGTs? Need4Boost Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 03-24-2005 11:28 AM
Considering DP, can this cause High EGT? tower210 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-11-2005 08:08 PM
boost leak cause high egts? WRXout Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 09-16-2004 11:03 AM
can an uppipe leak cause my car to feal sluggish? vapore0n Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-18-2003 10:17 AM
