Old 07-10-2008, 05:28 PM   #1
SubbyOBS
Member#: 124035
99 LOB and RS
Default OEM Air Intake box
I recently got the adaptor for the cone filter for my 99 Subaru Legacy OB, however, when I tried to attach the cone filter it was touching the ABS module at the right side (where the air intake box is installed by Subaru).
My question is how to remove the air intake box? It looks like there are two screws attached to the frame.
Also, does anyone has the HKS 'mushroom' air filter (the green one)? Anyone know is the diameter for the mushroom screwed to, is that 3" diameter?
SubbyOBS is offline   Reply With Quote
Old 07-10-2008, 06:15 PM   #2
fastenova
Member#: 38829
Not your usual 1997
Legacy GT
There should just be 2 10mm or 12mm bolts close to the motor that go down into the front subframe. Then just pull the airbox towards the motor (it has a little nub that sits in the fender wall) and that's it.
fastenova is offline   Reply With Quote
Old 07-11-2008, 08:49 PM   #3
iluvdrt
Member#: 46248
82 Brat
Tan
pulling the snorkus is a little work though.
iluvdrt is offline   Reply With Quote
Old 07-11-2008, 10:26 PM   #4
Huffer
Member#: 36735
99 GF8 Impreza 2.0
2= 1998 BD + BK Legacy GT
????? That's not even a 10min job.
Huffer is offline   Reply With Quote
Old 07-12-2008, 10:36 AM   #5
iluvdrt
Member#: 46248
82 Brat
Tan
Mine was bolted to inner fender (with a 10mm), and the thing was so huge I had to take loose the fender (also 10mm). It was PIA....and a 10mm job.
Old 07-12-2008, 12:11 PM   #6
Benfolio
Member#: 128805
97 White OBS ECSB
NO ITS NOT A SUBARU
You have to move the fender liner out of the way, but it really just needs a good yank to come out after you unbolt it.
Benfolio is offline   Reply With Quote
Old 07-12-2008, 04:30 PM   #7
iluvdrt
Member#: 46248
82 Brat
Tan
I have JDM fogs, they were in the way. It was a little for me.
Wanted: '06-'07 OEM Air Intake Box resipsawrx Private 'Wanted' Classifieds 3 11-25-2009 12:35 AM
OEM WRX Air Intake Box and Filter BoXXy TXIC Private Classifieds 1 06-25-2009 08:48 PM
MA/CT - OEM Air Intake Box Mint BONFIRE074 Engine/Power/Exhaust 3 05-29-2009 09:52 AM
FS: So Cal 07 STI full turboback, heat shield, intake silencer, air intake box bugeyeblue Engine/Power/Exhaust 7 12-28-2007 04:09 AM
OEM WRX air intake box w/ ITG air filter djerickd Private 'For Sale' Classifieds 1 07-09-2006 06:56 PM
