#1 |
Vendor Sales Rating: (65)
Member#: 23216
Vehicle:2006 949-457-1234 949-457-1234 |
There here guys! Helix Downpipes in stock. Also all Gruppe-S manifolds come with a free Helix Up-Pipe. Also Dont miss out on our awesome turbo combos in stock ready to ship.
Helix Downpipes In Stock Ready To Ship ![]() Non-Catted Downpipe $225 Shipped Catted Downpipe $349 Shipped ****Coming Soon Helix Downpipes for 2008 WRX/ STi**** Helix Turbo Back Exhaust ![]() Performance Exhaust Helix Non-Catted DP/HKS Hi-Power- $725 shipped Helix Catted DP/HKS Hi-Power- $825 shipped Helix Non-Catted DP/HKS HKS Carbon-Ti- $775 Helix Catted DP/Greddy Ti-C $949 shipped Helix Non- Catted DP/GReddy TI-C- $725 shipped Helix Non-Catted DP/Blitz NUR Spec- $725 shipped Helix Catted DP/Blitz NUR Spec- $849 shipped Quiet Exhaust Under (93db) Helix Non-Catted DP/A'Pexi World Sport- $675 shipped Helix Catted DP/A'Pexi World Sport- $799 shipped Helix Non-Catted DP/Apexi WS NOIR- $699 shipped Helix Catted DP/Apexi WS NOIR- $825 shipped Helix Non-Catted DP/GReddy SP2- $975 shipped Helix Catted DP/GReddy SP2- $849 shipped Helix Non-Catted Dp/Tanabe Medalion Touring- $725 shipped Helix Catted Dp/Tanabe Medalion Touring- $849 shipped Gruppe-S Exhaust Manifold Free Helix Up-Pipe ![]() ![]() The Gruppe-S manifold is a 4 to 1 unequal length manifold. It will retain your boxer rumble and features T304 Stainless Steel piping, mandrel bends, and CNC precision cut flanges. The 4-1 collector is cast to ensure the smoothest possible low rates. This header is dyno proven to make power; it will not lose power or torque in 2.5L applications anywhere in the RPM range. 2.0L motors will lose some low-end and mid- range power to gain more high-end power and torque. The more modified your vehicle is, the more pronounced the gains from these headers will be. The outside coating eliminates heat loss from the exhaust gasses (as compared to stock headers). Because warmer air travels more quickly and expands more quickly, this helps to spool the turbo more quickly Constructed from T304 Stainless Steel piping, mandrel bends, and CNC precision cut flanges. Dyno proven to make up to 8hp and 12 ft-lbs of torque. The design of the Gruppe-S equal length manifold increses boost response. Spool up time is decreased incresing boost pressure at lower RPM's. Due to the exhaust pulses now being paired together the lumpy boxer sound is lost instead a smoother sound is produced. ****2.0L Engines Require 2.5L Oil Pan For Manifold Clearance**** Un-Equal ***Free Helix Up-Pipe*** $425 Shipped Equal Length ***Free Helix Up-Pipe*** $649 Shipped BC Cams Free Gruppe-S Lightweight Crank Pulley ![]() After months of testing the BC camshafts are finally available. Stage 2 (272)-Street/Strip Specification Plug and play application. Short duration for nice street manners, slight lope at idle. Excellent all purpose spec. OEM springs OK. Stage 3 (280)- Race Specification Longer duration profile, added rpm potential. Intended for fully built engine. Tuning and ECU mods recommended. Requires spring kit. WRX 272 WRX 280 STi 272 STi 280 PM For Best Price Anywhere. All competitors Prices Beat! Guaranteed! (price match must be from an authorized BC distributor) Dont Forget to Add BC Valvetrain Components ![]() Brian Crower Spring/Retainer Kit $225 Shipped Brian Crower Intake/Exhaust Valves $249 Shipped Looking for a complete BC Drivetrain Combo? PM For Best Price Anywhere. All competitors Prices Beat! Guaranteed! (price match must be from an authorized BC distributor) Engine Rebuild Kits ![]() EJ20 Engine Combo/ EJ25 Engine Combo Good Up To 600 whp -CP (standard size) or (+020 overbore) Pistons -CP Piston Rings -Helix Forged Rods -Coated Race Bearings $799 Shipped EJ25 Budget STi Engine Rebuild Kit -USDM STi Pistons -USDM STi Piston Rings -USDM STi Rods -USDM STi Bearings $499 Shipped V34 Turbo Package +40 WHP Upgrade ![]() The IHI VF-34 Turbo is found on the limited production Subaru v7 WRX STI-RA (GDB). This turbo is differentiated from the VF30 through it's more advanced bearing design. The bearing design allows for much quicker turbo spool-up (depending on tuning, 300-500+ RPMs over the VF30), while retaining the power capabilities of the VF30. The VF34 is capable of 350+ HP (~300+whp) This turbo is a direct bolt-on for all GC8, GDA, GDB EJ20 turbo engines. This is an excellent replacement turbo for those looking for substantial power gains while maintaining streetability. - IHI VF34 Turbo - STI 565cc Injectors, - Walbro GS342 Fuel Pump w/ setup kit IHI VF34 Turbo 375HP Package Now $1375 Shipped VF34 Turbo $899 Shipped MHI 18G Turbo 400HP Package +50 WHP Upgrade ![]() The new MHI TD05H 18G turbo for Subabru WRX. With 7cm2 turbine housing, also included are water lines and oil drain line. This high-powered upgrade is good for 400 HP and flows 600 cfm! 1yr warranty. This turbo is a direct bolt-on for all GC8, GDA, GDB EJ20 turbo engines. -MHI 18G Turbo - PE 650 or 800 cc Injectors, - Walbro GS342 Fuel Pump w/ setup kit MHI 18G Turbo 475HP Package $1999 Shipped MHI 18G Turbo $749 Shipped ATP GT30 Turbo 450HP Package In Stock!!! ![]() Xtreme EVO Killer System -GT3076R/ or GT3071R Turbo -Hydra EMS -Perrin 3" Turbo Inlet Pipe -Denso 860cc Injectors -Walbro 255 lph Fuel Pump - w/ Setup Kit $3999 Shipped to the door. Pro Max System -GT3076R/ or GT3071R Turbo -Cobb Accessport -Perrin 3" Turbo Inlet Pipe -Denso 860cc Injectors -Walbro 255 lph Fuel Pump - w/ Setup Kit $3199 Shipped Street System -GT3076R/ or GT3071R Turbo -Cobb Accessport -Denso 860cc Injectors $2950 Shipped ATP GT3076R/ or GT3071R Turbo $1799 Shipped
__________________
Thanks, Gruppe-S To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Please Note: - All Competitors Prices Beat - All Items Are Shipped Via FEDEX - All Orders Are Repackaged To Help Prevent Any Damage Which May Occur During Transit - Any Order Cancellation Will Result In A 25% Processing Fee - Local Pick-Ups Available - No Cancellation on JDM Or Special Orders. No Exceptions! Last edited by Gruppe-S; 08-05-2008 at 09:43 PM. |
#2 |
Member#: 23216
Hey guys I have a few awesome Open Box Specials
Limited Quantities available so Act now. Perrin STi (04-06) Fuel Rail Combo 1 At This Price ![]() 1- Perrin Side Feel Fuel Rails 4- Helix 860cc Injectors 1- Walbro 255 Fuel Pump Kit $750 Shipped Perrin Turbo Inlet 1 At This Price ![]() Red Silicone Left In Stock $175 Shipped Spearco TMIC Save $$$ Over Brand New ![]() Brand New Display Units no Damage At All WRX/ STi $725 Shipped Gruppe-S Pulley Combo Save 5.4 lbs. Of Rotating Mass ![]() AEM Alternator Pulley AEM Alternator Belt Gruppe-S Lightweight Crank Pulley $125 Shipped
__________________
Thanks, Gruppe-S To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Please Note: - All Competitors Prices Beat - All Items Are Shipped Via FEDEX - All Orders Are Repackaged To Help Prevent Any Damage Which May Occur During Transit - Any Order Cancellation Will Result In A 25% Processing Fee - Local Pick-Ups Available - No Cancellation on JDM Or Special Orders. No Exceptions! Last edited by Gruppe-S; 07-11-2008 at 06:07 PM. |
#3 |
Member#: 23216
__________________
Thanks, Gruppe-S To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Please Note: - All Competitors Prices Beat - All Items Are Shipped Via FEDEX - All Orders Are Repackaged To Help Prevent Any Damage Which May Occur During Transit - Any Order Cancellation Will Result In A 25% Processing Fee - Local Pick-Ups Available - No Cancellation on JDM Or Special Orders. No Exceptions! |
#4 |
Member#: 23216
__________________
#5 |
Member#: 23216
__________________
#6 |
Member#: 23216
__________________
#7 |
Member Sales Rating: (1)
Member#: 178629
Performance Exhaust
Helix Non-Catted DP/HKS Hi-Power- $725 shipped Helix Catted DP/HKS Hi-Power- $825 shipped Helix Non-Catted DP/HKS HKS Carbon-Ti- $775 Helix Catted DP/HKS HKS Carbon-Ti- $949 shipped Helix Catted DP/GReddy TI-C- $725 shipped Helix Non-Catted DP/Blitz NUR Spec- $849 shipped Helix Catted DP/Blitz NUR Spec- $725 shipped Why is the Helix Non-catted dp / Blitz Nur Spec more expensive than the Catted version? |
#8 | |
Member#: 23216
Thanks Ben Helix Non-Catted DP/Blitz NUR Spec- $725 shipped Helix Catted DP/Blitz NUR Spec- $849 shipped
__________________
#9 |
Member#: 23216
Bump!!!
__________________
#10 |
Member#: 23216
__________________
#11 |
Member#: 23216
__________________
#13 |
Member#: 23216
__________________
#15 |
Member Sales Rating: (2)
Member#: 68129
HIIC
Vehicle:2001 Impreza RSTi White |
is the Helix non-catted downpipe still $225 shipped........do they all come with the EWG flange built in? if so does it come with a block off plate?
#16 |
Member#: 23216
__________________
#19 |
Member#: 23216
__________________
#20 |
Member#: 23216
__________________
#21 |
Member#: 23216
__________________
#22 |
Member#: 23216
__________________
#24 |
Member#: 23216
__________________
| Thread Tools | |
| Display Modes | |
| VF34/VF22 In Stock-Equal Length Manifold Free Up-Pipe-Cheap Turbo Backs | Gruppe-S | Engine/Power/Exhaust | 32 | 03-20-2008 09:23 PM |
| Accesports in Stock-Gruppe-S Manifolds Free Up-Pipe-Helix Downpiper $199 | Gruppe-S | Engine/Power/Exhaust | 15 | 02-28-2008 07:46 PM |
| Accesports in Stock-Gruppe-S Manifolds Free Up-Pipe-Helix Downpipe $199 | Gruppe-S | Engine/Power/Exhaust | 2 | 02-20-2008 08:58 PM |
| Gruppe-S Equal Length Manifold-Free Up-Pipe-Engine Rebuild $899-All Helix On Sale! | Gruppe-S | Engine/Power/Exhaust | 46 | 02-20-2008 08:07 PM |
| Helix Downpipes In Stock | Agile Auto | Engine/Power/Exhaust | 0 | 09-08-2005 01:11 PM |
