Old 07-10-2008, 11:31 PM   #1
cucamelsmd15
Member#: 122980
2010 F150, 2013 CX-5
92 Miata 15 TTF/PTF/E3
Default Looking for all season tires, with a twist!
I need to replace the well-worn RE92's this fall, so its time to start looking.
Things I want:
Good snow traction
Good off road traction
Long life
Decent price
Things I could care less about:
Dry performance
Sidewall stiffness
Brand
These are going to be mounted on 17x7 stockers from an 06 WRX (obviously). As these will see alot of snow/sand this winter/spring, traction is my biggest concern. I think this pretty much rules out any of the high performance all seasons (and that goes for long life too).
So, whatcha got?
cucamelsmd15 is offline   Reply With Quote
Old 07-10-2008, 11:33 PM   #2
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
Winterforce...
http://www.tirerack.com/tires/tires....ireModel=M%2BS
Lots of hicks round here run them year round...
Old 07-11-2008, 12:06 AM   #3
Weedy
Member#: 12340
2002 WRX 2.5L Hybrid
I got the Nitto NT450 to replace the stock RE92's. I think they are pretty darn good, especially in the winter. Since they aren't winter only tires they also work well if you have a warm winter. Not a bad price I thought when I got them originally for a basic OEM replacement. I know you mentioned the high performance all season's might not be for you, but I think we have just as bad if not worse winters normally than in your area.
Weedy is offline   Reply With Quote
Old 07-11-2008, 12:30 AM   #4
Fendyman
Member#: 21542
2011 Impreza 2.5i
Dark Gray Metallic
Originally Posted by Aaron'z 2.5RS View Post
Winterforce...
I believe that is Studdable Winter tire...
I think ContiExtremeContact would suit your need, but I don't have any experience w/ it, so don't quote me. It has the highest rating for snow traction among other UHPAS tires.
Fendyman is offline   Reply With Quote
Old 07-11-2008, 12:41 AM   #5
nhat
Member#: 140163
03 STi
hellaflunctional
nokian wr or wrg2.
Old 07-11-2008, 07:52 AM   #6
cucamelsmd15
Member#: 122980
Winterforce...
None in my size.
Originally Posted by nhat View Post
nokian wr or wrg2.
Damn, those are exactly what Im looking for, but they are pricey from what Ive seen.
Old 07-11-2008, 12:14 PM   #7
growling_boxer
Member#: 165744
2000 LGT
2007 STi
if you're going for off-road performance from an A/S tire, i've repeatedly heard the BFGoodrich KDW-whatevers (forget the exact model number for the A/S) recommended on dirtyimpreza.com. the nokians are mentioned regularly as well.
as far as winterforces (which is what i use when rallycrossing my legacy), they are a winter tire, but the compound is not as soft as most, so it shouldn't wear out as quickly. this is also the reason they are so cheap. but you will probably have to wait for winter to get nearer before finding these in stock. you could try calling around to firestone/bridgestone delaers, since they make the winterforce tires. i know you said you don't care, but i'll mention it anyway...these will have a softer sidewall than the A/S tires. people often run them at 40psi when sliding around in the dirt to avoid debeading as easily.
growling_boxer is offline   Reply With Quote
Old 07-11-2008, 01:56 PM   #8
subenerd
Member#: 72630
2004 STi
Avon Tech M550 worked decent for me in Tahoe. Not the best in the ice, however.
subenerd is offline   Reply With Quote
Old 07-11-2008, 03:31 PM   #9
growling_boxer
Member#: 165744
2000 LGT
2007 STi
i don't think any A/S tire i've used is good on ice.
Old 07-12-2008, 12:12 AM   #10
Dtown2point5
Member#: 44702
2002 Impreza WRX
I've had good luck in All Weather with Pirelli P-Zero Nero M+S on my RS.
Snow was not a big deal, in the rain they were plain out confidence inspiring.
I went through 2 sets and got about 40,000 miles/set (but they were beyond done at that point)
Dtown2point5 is offline   Reply With Quote
Old 07-12-2008, 12:38 AM   #11
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Goodyear TripleTred assurance
#1 rated all season tire @ tirerack.com
Heavy but amazing tread wear!
Old 07-15-2008, 05:05 PM   #12
Huffer
Member#: 36735
99 GF8 Impreza 2.0
2= 1998 BD + BK Legacy GT
Hankook Winter iPike's are nice. I have the Hankook W300 "Icebears" and they're decent, but the iPike's are more aggressive for slush and snow.
Huffer is offline   Reply With Quote
Old 07-15-2008, 05:46 PM   #13
Luke@tirerack
Tire Rack Moderator
Member#: 1215
ext. 4362
BF Goodrich Traction T/A is very popular amongst the Rally Crossers
Old 07-15-2008, 06:19 PM   #14
leecea
Member#: 37359
2003 WRX
Wintersport M3 or 3D - not really an all season but thinks it is
leecea is offline   Reply With Quote
Old 07-15-2008, 07:31 PM   #15
Trigger
Member#: 102366
2006 Impreza Wagon
I'm putting the Nokian WR-G2 on the wife's '06 Impreza 2.5i wagon this fall when they go on sale.
Apparently the only all season tire with the snowflake icon.
Trigger is offline   Reply With Quote
Old 07-16-2008, 01:36 AM   #16
snovvbrdr
Member#: 121063
2006 WRX Stg. II
Steel Gray
Assuming you live in NC (as you profile states), i think any true snow tire would be over kill and wear out with in a year (depending on how hot it gets) I do agree that the hankook I*pike is a great snow tire as stated above as is the toyo observe would be another good snow tire option
snovvbrdr is offline   Reply With Quote
Old 07-16-2008, 06:54 PM   #17
mummer43
Member#: 113985
2006 Outback Sport
Steel Grey Metallic
nokian wr or wrg2.
Seconded. I am about to have the G2 mounted on my OBS. Got them for $140 a tire out the door.
mummer43 is offline   Reply With Quote
Old 07-17-2008, 02:57 AM   #18
Aspenbullet
Member#: 71240
2002 WRX Cobb Stg II
Aspen White w/Yakima Rack
I've had these for 4 seasons and they're very predictable in the snow and have a good life, not great but good.
I use these as my "winter" tires taking many many ski trips to northern NM, southern CO and grip very well in the snow for a UHPAS tire. They grip well on the dirt road shortcut on the way to Wolf Creek too. Good price as well. I would get them again when mine wear out.
Aspenbullet is offline   Reply With Quote
Old 07-17-2008, 11:33 AM   #19
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
And your point? It meets the critera, except for not being able to find a size match..
Old 07-17-2008, 12:54 PM   #20
Fendyman
Member#: 21542
2011 Impreza 2.5i
Dark Gray Metallic
Are you referring to Winterforce M+S? OP is looking for ALL SEASON tires... NOT winter tires. I'm not saying Winterforce M+S is not good, in fact I think it's better than ANY All Season tires in snow & especially on ice, but I don't think it's a good idea to roll on snow/winter tires in summer, just as nobody should roll on summer tires in winter/snow.
Old 07-17-2008, 01:57 PM   #21
mummer43
Member#: 113985
2006 Outback Sport
Steel Grey Metallic
Why don't you guys carry Nokian?
Old 07-17-2008, 02:28 PM   #22
Luke@tirerack
Tire Rack Moderator
Member#: 1215
ext. 4362
our business model conflicts with their distribution channels
Old 07-17-2008, 03:33 PM   #23
jyi
Member#: 147312
2007 WRX Stage 1
Black Obsidian Pearl
Things I want:
Good snow traction
Long life
Decent price
Dry performance
Sidewall stiffness
Brand
So, whatcha got?
It rarely snows in Raleigh why do you need snow traction?
I got the Bridgestone Potenzas 960as Pole Position All-season tires (225/45/17). Great traction on all grounds except for snow~ i guess that didn't help much ~
jyi is offline   Reply With Quote
Old 07-17-2008, 03:40 PM   #24
cucamelsmd15
Member#: 122980
Those look nice, so theyre on the list.
Not planning on driving them during the summer, I have a spare set of wheels/tires. These would probably be on from Nov-April, if that.
My wifes family lives in the mountains, and it snows fairly often. One trip on RE-92's was enough to convince me I wanted something better. We are planning on doing a bit of skiing this year too.
Plus, I might RallyX the car this fall.
Old 08-06-2008, 07:59 PM   #25
repawn
Member#: 183452
2002 Impreza WRX
Platinum Silver Metallic
I am running a set of the BFG Traction TA - I haven't driven them in our WI winter yet (replaced my tires June) but the wet traction has been great and the tires are pretty quiet as well.
repawn is offline   Reply With Quote
4 ProContact Continental tires 225/45/17 all season tires with 90% tread (NY) txl146 Private 'For Sale' Classifieds 1 03-10-2006 09:07 AM
WTB: NY Looking for all season tires in 215/45/17 or 225/45/17 WRXVII Tri-State Area Private Classifieds 0 02-04-2006 02:02 AM
FT: Bridgestone RE070 tires for all season tires WRXVII Tri-State Area Forum 0 01-15-2005 04:16 AM
Looking for all-season tire suggestions Kickerz Legacy Forum 12 11-25-2002 02:31 PM
Looking for all-season tire recommendation.. thrashvr6 Brakes, Steering & Suspension 5 10-23-2002 08:34 PM
