Old 07-11-2008, 06:47 PM   #1
wittmer25
Member#: 102970
2004 STi gt30r
Default Garret Turbo BB oil restriction fitting
Anyone know what size orifice fitting I need if my oil pressure is 95-100 psi? The garret website says my CHRA BB oil pressure should be kept around 40-45 psi at maximum engine rpm (max oil pump pressure). They say a .040" orifice is a common size for most passenger vehicles. Just curious if anyone knows.
wittmer25 is offline   Reply With Quote
Old 07-11-2008, 09:20 PM   #2
WRXINTX
Member#: 96712
.030 is what I use on my engine with 100PSI.....
Turbo hasn't complained yet....
WRXINTX is offline   Reply With Quote
Old 07-12-2008, 01:12 AM   #3
GeneralTJI
Member#: 152680
Yea I usually see it recomended at or around .035 for our motors which produce a pretty fair amount of pressure.
I have actually made about 5 restrictors for my setup until I found something that stopped pushing oil past the seal (Not Ball Bearing) and ended up around .055 They say BB turbos need a fair amount less than journal bearings.. So I would start around .035 - .040 and see what happens...
GeneralTJI is offline   Reply With Quote
Old 07-12-2008, 01:17 AM   #4
Optical NZ
Member#: 120463
Garrett sell a restrictor that has a 1mm (0.040") aperture. I still think it could be smaller as my turbo is still over oiled!
Optical NZ is offline   Reply With Quote
Old 07-21-2008, 04:39 PM   #5
STIBungy
Member#: 51684
ATP sells a .035 restrictor for the GT turbos.
STIBungy is offline   Reply With Quote
Old 07-22-2008, 09:49 AM   #6
bluescoobywagon
Member#: 14911
Not A Wagon!
2011 WRX - 285s on 18x9.5
Is it this one?
bluescoobywagon is offline   Reply With Quote
Old 07-22-2008, 03:46 PM   #7
flycaster
Member#: 60142
2011 WRX
Grey
IIRC, I ended up with a .025" in my system. All these CHRA's need is a constant supply, not any real "pressure." I started out with a .040" and I got oil puke out of the front seal. I'd start with that and then take it down until it just barely stops pushing any oil - better a little too much than not enough.
flycaster is offline   Reply With Quote
Old 07-22-2008, 04:19 PM   #8
wittmer25
Member#: 102970
2004 STi gt30r
Thanks! I will try a .025".
Oil restriction in bearing galleries masterx81 Built Motor Discussion 6 06-06-2010 06:51 PM
Stock AVCS Line Turbo Oil Feed fitting bugeyesubie Newbies & FAQs 1 04-06-2010 01:01 AM
F/S (MI) turbo oil feed fittings. 9d2TSi Engine/Power/Exhaust 3 10-04-2009 10:30 PM
oil restricters on built motors. capitalj4 Built Motor Discussion 13 09-27-2009 08:39 PM
will vf turbo water and oil lines fit td05 16g? simprezl25 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 06-02-2007 05:44 AM
