Old 07-11-2008, 07:52 PM   #1
UP2MTNS
Member#: 112405
2004 WRX Rally Car
Silver, Black, and Decals
Default Little help on cruise control wiring....diagram anyone?
Hey all,
so I seem to have lost my $10 ebay WRX manual CD.....dammit!!
can anyone tell me how the cruise control works? I've taken it apart....can't see which wires do what.....I assume 12v are sent to the control 'stick' and when you move it up/down/back it sends that 12 volts to the CC controller to either set/accel/decel/cancel?
can you tell me which colored wires do which? I only need to know which wire is the 'set' one.
TIA.
UP2MTNS is offline   Reply With Quote
Old 07-11-2008, 09:15 PM   #2
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
Looking at some data it shows the SET contact is tied to a light green/blk wire that goes to pin 10 on the cruise control module. The other side of the switch contact ties to power for the horn relay via a red/grn wire.
Old 07-12-2008, 01:01 AM   #3
UP2MTNS
Member#: 112405
2004 WRX Rally Car
hmmmm, thx.
I have a green wire w/red stripe = 12v (confirmed)
then:
Black wire
Black wire with white stripe
White wire.
so maybe the colors are a little different, but I assume the black/white wire is the 'set' wire? sounds like it....I'll do a little test wire up and see if that works. thx.
Old 07-12-2008, 01:19 AM   #4
UP2MTNS
Member#: 112405
2004 WRX Rally Car
oh......so what I"m doing....pulled my oem wheel off (cruise control and horn stopped working) and replaced it with a sparco wheel. re-wiring the horn is easy, but now I want to rig a button on the wheel that will 'set' the cruise. That's all I need.....don't need the other 'cruise' functions...just need to set it.
any recommendations on how to set that up? 12v power to the button.....button return wire goes to the 'set' wire?
Old 07-12-2008, 01:49 AM   #5
Cougar4
Member#: 53443
Winestone
You will need a momentary switch tied between power and the SET wire. You may be able to trace the wire back to the module. My info shows pin 10 is the SET wire.
Old 07-14-2008, 02:18 AM   #6
UP2MTNS
Member#: 112405
2004 WRX Rally Car
got it to work!! Thanks Cougar4.....very fun to control my CC from my new sparco steering wheel. cheezy....but fun
for reference....it was the black wire with white stripe....this is the wire coming out of the dash and BEFORE it goes into the steering wheel. interesting that the wire colors straight out of the dashboard are not the same color as the wires actually inside the steering wheel.
Old 07-14-2008, 04:32 AM   #7
Cougar4
Member#: 53443
Winestone
You're welcome. Glad you got it working.
2008 cruise control wiring diagram xxscaxx Electrical & Lighting 4 03-09-2010 01:30 PM
can anyone help me find a wiring diagram?? 555 WR Subaru Conversions 1 11-09-2006 11:56 AM
need help on 02RS ecu wiring diagram SFimpreza411 Normally Aspirated Powertrain 8 06-13-2002 10:38 PM
Cruise Control wiring diagram tmat3 Normally Aspirated Powertrain 7 06-13-2002 06:36 PM
