Old 03-05-2002, 11:16 PM   #1
wrextuner
Member#: 16008
2002 wrx
Default ok what next.....here`s the list of what we have and wondering what we need to do now
ok folks from what i seen so far there is a vast welth of knowledgle to pull from here so here we go
list of what we have done so far and what you all think we should do next....
blitz sbc-id...blitz powermeter i-d...ingen cold air intake w/ HKS power flow filter...vf-22 turbo...turbo x`s downpipe..high flow cat...zigen fireball cat-back...front mount intercooler with aluminium piping...STi motor mounts...and STi tranny mount..,
what I am looking at doing next is
ecu...which one will allow the best tunabilty for max gains...
up-pipe...
fuel system....to get the most from our turbo would a set of 620`s be overkill?
cams...all hype or real power houses?
on the suspension side all we done so far is the STi springs and a set of 17`s
the plan is for a set coil-overs
a cusco 24 mm rear adjustable sway bar
what is the valid reason for a set of adjustible pillow mounts?
if any one has any sugestions or any thoughts on what I should be doing to get the most out of this car as possible leave a post...
oh yes this is a autocross car and a street terror..so weight and handling are factors
wrextuner is offline   Reply With Quote
Old 03-05-2002, 11:58 PM   #2
cronic
Member#: 9749
wow sounds nice.. if price isnt an option get a standalone ems
cronic is offline   Reply With Quote
Old 03-06-2002, 12:28 AM   #3
wrextuner
Member#: 16008
2002 wrx
but the question is which one?
Old 03-06-2002, 12:30 AM   #4
A-spec tuning
Member#: 11359
02 WRX
Platinum
Definately stand alone if your looking for the most tuning ability.
A-spec tuning is offline   Reply With Quote
Old 03-06-2002, 01:00 AM   #5
TerenceT
Member#: 9510
04 FX35
Pearl White
how do you plan on stopping all those power?
TerenceT is offline   Reply With Quote
Old 03-06-2002, 01:13 AM   #6
wrextuner
Member#: 16008
2002 wrx
Default ahh...good point
seen the AEM big brake upgrade kit...least costly of all the alternitvesbut still ueses stock calipers....have a set of ebc green on the way just waiting for the back order to come in
Old 03-06-2002, 01:57 AM   #7
TerenceT
Member#: 9510
04 FX35
Pearl White
how about 4 pot sti/subaru caliper w/ pads and stainless steel brake lines?
grippy tires would help stopping too
also there's StopTech big brake kit upgrades too
Sti suspension top hats would help with handling too
adj pillarball mounts is for camber adjustment
Old 03-06-2002, 05:07 PM   #8
Szm426
Member#: 11679
get a brembo bog brkae kit! Also i think you shoudl get a stand alone system.
Szm426 is offline   Reply With Quote
Old 03-06-2002, 11:51 PM   #9
Conduit
Member#: 6162
MBP, 1st WRX Ever in FL.
I would take a look at the wilwood brake kit. It's on their main page.
If cost isn't that much of an issue, I would look at the Pectel T6 for your ecu needs. The AEM that isn't available yet looks quite nice as well, assuming you can wait.
Conduit is offline   Reply With Quote
Old 03-06-2002, 11:57 PM   #10
wrextuner
Member#: 16008
2002 wrx
Default pectel???
where can I get some reveiws on it? On the brake issue we have done what we are going to do for now we do have plans for the big brake upgrage...but I would like to get more advise on the ecm and if any one knows where I can get downloads of the recomendations so I see how easy it is to work with that would be great as well................
Old 03-07-2002, 12:47 AM   #11
nmyeti
Member#: 4980
Default Re: ok what next.....here`s the list of what we have and wondering what we need to do now
not a real big gain in cams... The stock cams are pretty good based of my conversations with both trey cobb and Sam rigioli.
The best cams that will work with the standard valve train are the 97-98 WRX cams... the us spec 02 cams are VERY close to these... much better than the rest of the world get.
-Nathan
nmyeti is offline   Reply With Quote
Ever have something you know you need to do for yourself, that you cant. huckedup16 Off-Topic 23 02-18-2004 12:37 PM
OK the list of whats going to be available...no prices yet spt_impreza Canada Region Forum 18 06-22-2003 09:44 PM
ATTN: Texas Boys! Here 's what we need to do..!! ExchangeGuy Texas Impreza Club Forum -- TXIC 38 08-30-2001 06:49 PM
('93-'01) what do i need to do to try and get an autocross/Solo2 here...HELP! SuBaRu-ImPrEzA_RS Impreza Forum 2 06-03-2001 10:11 PM
OK add my name too the list of wrx's scoobyruman New England Impreza Club Forum -- NESIC 19 05-14-2001 08:43 PM
