Old 07-12-2008, 07:59 PM   #1
wrx425
Member#: 161582
white
Default cigarette lighter help!
so i just bought a radar today, and when i try to turn it on, it doesnt work! i was abought to return it when i thought maybe it wasnt the radar, but my cigarette lighter. i tried the radar in my sisters car and it works fine. It seems like my ciggarette lighter isnt producing any power for the radar, has anyone had a similar problem??? help!
wrx425 is offline   Reply With Quote
Old 07-12-2008, 08:05 PM   #2
CF-Ninja
Member#: 143114
2007 Impreza 2.5i
CGM
pop off the trim piece and make sure the wires are hooked up right, also check the fuse. If both look normal you might have to poke around with a DMM. Just hardwire it under the dash, it will look cleaner anyways.
CF-Ninja is offline   Reply With Quote
Old 07-12-2008, 08:14 PM   #3
Boostinbildo
Member#: 163892
05 AW STI:SOLD
Black 93 Singled tt Supra
I had the same problem a while back, it was my fuse. If your power mirrors dont work, its definately the fuse because they run off the same fuse as the cig lighter. Well, at least it was like that in my 04, maybe bugeyes are different. But yeah, hardwire it anyways I hardwired my radar and it looks super clean.
Boostinbildo is offline   Reply With Quote
Old 07-12-2008, 08:16 PM   #4
wrx425
Member#: 161582
white
how do i hardwire it?
Old 07-12-2008, 08:20 PM   #5
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
I would blame the fuse. Not sure which radar you bought, but even the smallest maritime units have a 2kW output. Feeding them at 12 V, it's close to 200 amps, whereas the cigarette lighter is rated at 10
Old 07-12-2008, 08:45 PM   #6
CF-Ninja
Member#: 143114
2007 Impreza 2.5i
CGM
If you want to do it the EXTREMELY easy way go to autozone or the like and get the spare 12v jack and wire it to your existing 12v outlet. It took me about 15 minutes total including solder and heat shrinking. I used some 2sided tape to attach the spare outlet under the dash. Now you can't see any wires on my XM radio.
If you can't solder or don't have an iron you can always get 2 barrel connectors and splice them into the line. Either way will work just as good.
This way you don't have to cut off the fused 12v plug on the radar detector and you can remove it if need be.
Old 07-12-2008, 10:42 PM   #7
CF-Ninja
Member#: 143114
2007 Impreza 2.5i
CGM
hey.. saw your other thread... you just pull the trim around your shifter to get to the back of the lighter
Old 07-13-2008, 01:29 AM   #8
Dutch Scooby lover
Member#: 32452
1998 Impreza Turbo
74F FTW
If the fuse and connections are good it could also be the fusible link on the lighter itself.
This is a piece of wire, which melts incase you overload the lighter socket.
It is at the back of the lighter itself, and is a piece of wire about 1mm thick, 20 mm long and bent 90 degrees in the middle.
Don't ask how I know this , lets just say the Socket can't handle a 340 watt 220 VAC inverter
Dutch Scooby lover is offline   Reply With Quote
Cigarette Lighter help please. StealthfishWRX Newbies & FAQs 4 12-19-2009 02:07 PM
dumb thing to do, cigarette lighter help please ! subjfd Legacy Forum 7 02-09-2006 08:04 AM
Tapping Cigarette lighter for power (NEED HELP ASAP) UGoWeGo Forester Forum 5 01-10-2005 07:53 PM
Cigarette lighter not working on New 05? Help lightpost12 Electrical & Lighting 14 12-04-2004 08:55 PM
Help ASAP> Cigarette Lighter plug Problem WRallyBlue02 Electrical & Lighting 1 03-05-2004 08:01 PM
