View Poll Results: Exhaust piping???
Just build a good full 3'' down/pipe and keep the Lachute 3'' exhaust 10 71.43%
Build a Full 3.5'' turbo/back exhaust 3 21.43%
Build a Full 4'' turbo/back exhaust 1 7.14%
Voters: 14. You may not vote on this poll
Old 07-13-2008, 11:44 AM   #1
OB2
Member#: 51500
1999 impreza rs-t
sylver
Default exhaust question???
I do have a 99 RS-T with a ej257 forged engine, SOHC head and a GT3076R turbo that push around 345 whp!
I have a custom made Down-pipe starting at 2.5'' for 10 inch and go biger (3 inch) for the rest of pipe and everythink finish with a 3''Lachute Cat/Back !
The question is???: My car had alot of lag and not as much HP that I sould have for 22PSI on a GT30R turbo Do you think a biger Turbo/Back piping (full 3'' or 3.5'' or 4'')should help everythink?
OB2 is offline   Reply With Quote
Old 07-13-2008, 12:25 PM   #2
KenSekiguchi
Member#: 175331
2002 WRX STi - WRB
JDM V7 EJ207/13' Felt Z85
Why wouldn't you just pick up a 4" TXS downpipe and then get the APS 3.5" catback? If it's not in your budget, then a custom 3" should be enough. I've read that anything over 3.5" - 4" won't get you anymore performance than a 3" unless you're running a huge turbo @ 30+ psi. Just my 2 cents though.
KenSekiguchi is offline   Reply With Quote
Old 07-13-2008, 01:01 PM   #3
Dom'sGurl
Member#: 150837
2006 Legacy GT
Try cams. I had a lot of lag on my GT3076R and cams helped a ton. The TWE cams or even the Delta Regrinds work great. I have the same style downpipe as you with a Tial 38mm wastegate and I put down 406wtq and 367whp on a Mustang dyno.
what are you using for engine management?
Dom'sGurl is offline   Reply With Quote
Old 07-13-2008, 02:53 PM   #4
OB2
Member#: 51500
1999 impreza rs-t
sylver
I allready have TWE Stage 3 cams but I have nothing before 4000RPM and everythink drop dead after 6500RPM! Look at my setup and my dyno graf and please help me to get 400over WHP???
MOTEUR:
Stock SOHC Head
TWE Stage 3 turbo Cams(272 HKS)
Wiseco [email protected] compression Piston
K1 Carrillo Rod
Cosworth bearing
Cometics head gasquet
ARP stud
Lachute Hi-Flow oil pump
Cosworth belt retaner
Gates Racing Belt
Lachute 3" Turbo/Back Exhaust
Zero Sport Radiator Wind Deflector
Halley Fuel Pump (650 hp)
K&N Air Filter and Intake
Turbo XS Blow off Valve
ASR 2.25" Up-Pipe
Gready Front Mont Intercooler
Garrett GT3076R ar.82 Turbo
Turbonetics Delta-Gate Wastgate
Turbonetics Manual Boost Controler (Set at 22 psi)
FAL Engine Cooler
Unorthodox Racing Full Pulley Kit
Power Entreprise 850cc Injectors
SUNO Automobile HYPER GROUND SYSTEM
Custom IC water foger
HYdra Nemesis EMS
Old 07-13-2008, 09:54 PM   #5
Dom'sGurl
Member#: 150837
2006 Legacy GT
Your graph is very interesting....
Seems like something else is going on.
Have you verified no boost leaks? Does your wastegate dump externally or recirc?
These heads are more efficient in the midrange as you can see by my graph above. I don't have any porting and my cams are only stage 2s. My turbo is also a GT3071R with a .63 A/R. So that would have a bit to do with the better spool on my setup. However, your larger cams should have helped out more than that.
I'm still shooting for a boost leak or a wastegate leak. You wanna shoot me an email with your tune file? Maybe I can see something in there.
Old 07-14-2008, 12:49 AM   #6
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Weird looking dynosheet to say the least.
I suspect tuning and mechanical issues.
Until recently I was using a 2.5" (or is it even smaller?!?!) NA Borla header with custom uppipe that was SMALL! and no problems spooling.
Old 07-15-2008, 01:16 AM   #7
Dom'sGurl
Member#: 150837
2006 Legacy GT
I'm using the borla N/A header as well with no issues.
something isn't right with the OP's engine or possibly the tune.
08 STI exhaust on 08 WRX Exhaust Questions J-Rod 555 Newbies & FAQs 6 06-08-2009 03:58 PM
Exhaust Question for a QUIET Exhaust.. The Blue Pilot Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 29 01-19-2008 11:54 PM
Full OBX Exhaust? General exhaust questions. stoney98 Normally Aspirated Powertrain 12 06-18-2007 11:39 AM
Aftermarket exhaust question. The older the exhaust gets, the raspier? 2005wrbluesti Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 12-12-2006 10:16 PM
Aftermarket exhaust question. The older the exhaust gets, the raspier? 2005wrbluesti Normally Aspirated with bolt-on Forced Induction Powertrain 0 12-12-2006 03:52 PM
