Old 07-13-2008, 02:29 PM   #1
summitwrx
Member#: 148476
2002 impreza wrx
psm
Default Hella 500 Wiring Question.
Hey guys ive searched a few times and come up with nothing so heres my question.
Can i wire up four Hella 500 lights using one wiring harness? just wire up the blue wires and black wires for each light together? This way i dont have to run two different switches?
Please let me know what you think....
summitwrx is offline   Reply With Quote
Old 07-13-2008, 04:22 PM   #2
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
I haven't wired up these lights myself but I assume they use a relay to control the power to them. If that is the case and you have two relays, one for each set of 2 lights, I recommend you use both relays and tie the two coil leads in parallel, with a switch tied to power in series to one side of the coils and the other side of the coils tied to ground. To provide power to the lights use a fused power lead connected to the battery that can more than handle the combined current needed for the four lights. You may need about a 10 gauge wire for that. Then split the other end to the relays using two short 12 gauge wires, tieing one wire to each of the two relays switched contacts. Tie the lights to the other side of the contacts. If you want to use a single relay be sure to use one that will more than handle the required current needed by the lights. I would use at least a 10 amp safety factor.
Old 07-13-2008, 09:41 PM   #3
aerosaaber
Member#: 33850
2006 WRX Wagon
WRC Blue
I agree with cougar, one relay running 4 lights would probably be too much, but it's easy to use one switch to actuate two relays. If you're already wiring one switch a second wouldn't be bad, and you could maybe get a 3 position switch to control both sets (one on+one off / both on / both off). I'm not sure where to find something like that but I'm sure they're out there somewhere.
aerosaaber is offline   Reply With Quote
Old 07-14-2008, 12:40 AM   #4
summitwrx
Member#: 148476
2002 impreza wrx
psm
How would i wire one switch to actuate two relays? Anybody thats great at drawing up wiring diagrams please chime in. haha really i appreciate the help guys. Thanks.
Old 07-14-2008, 03:29 AM   #5
Cougar4
Member#: 53443
Winestone
As I stated before, you connect the coil leads of the relays together, in parallel with each other. Then connect them to the switch circuit.
Hella 500 Wiring Issue... Carter Electrical & Lighting 1 10-08-2008 11:11 PM
Hella 500 Wiring (and other ?s) NaturallyAspirated Electrical & Lighting 1 08-15-2007 10:45 AM
Hella 500 wiring question skidude6920 Electrical & Lighting 7 06-14-2007 04:59 PM
Hella 500 wiring question Mr. Sadface Electrical & Lighting 4 12-12-2006 11:53 PM
Hella 500 wiring ?? Rock_Strongo Electrical & Lighting 3 05-22-2005 03:47 PM
