Old 07-13-2008, 07:19 PM   #1
taossti
Member#: 145445
05 Time Attack STi
Default Use a wrx case or STi case if sleeving??
Just as the title states: use a WRX case or an STi case if your sleeving the motor anyway?
Not sure if there were any other reasons for staying with the STi case.
Power will be around 700 at the crank and yes, I will be using good parts too.
Thanks in advance.
taossti is offline   Reply With Quote
Old 07-13-2008, 07:57 PM   #2
Whiteghost 2.5
Member#: 72994
2001 Racekor
Emerald Green
The STi case is a semi closed deck and the wrx is open. The sti has a couple braces that connect the cyls to the outside of the case. Unless you are completely closing the deck of the WRX block the STi would be the ideal block to sleeve.
Josh
Whiteghost 2.5 is offline   Reply With Quote
Old 07-13-2008, 08:55 PM   #3
sti.2005.blk
Member#: 142014
build sheet?
sti.2005.blk is offline   Reply With Quote
Old 07-13-2008, 10:41 PM   #4
taossti
Member#: 145445
05 Time Attack STi
Whiteghost - You are correct. I shamefully admit that I did not notice or ignored the braces. That is a valid point and thus means I'll just use a STi case.
Build sheet- parts I already have: Darton sleeves, CP pistons, STi case, worked STi crank, various heads from Spec C to STi, and STi cams. parts needed are rods.
Thanks for the help.
Old 07-13-2008, 11:50 PM   #5
wrxwagon253
Member#: 125620
05 3076R Wagon
B5 S4 w/ Stg.3 RS6 kit
Arp fasteners and some Acl race bearings are also something you might wanna do. Why not just sleeve a Ej22t if your going for 700chp? That closed deck can take alot of abuse.
wrxwagon253 is offline   Reply With Quote
Old 07-16-2008, 12:24 PM   #6
charliew
Member#: 125304
amen brother wagon, lots more head sealing surface.
charliew is offline   Reply With Quote
Old 07-16-2008, 12:44 PM   #7
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
if you already have the sleeves, you have to use them with which ever block you chose...
which darton sleeves did you buy?
closed deck isn't needed for 700whp much less 700bhp...really all the EJ22t's are getting taken up by builds that require them...
save the money, do a sleeved STi block...the only reason I would see to sleeve an EJ20 block is if someone was going to build an extremely high rpm engine.
WTT: WRX TR two tone INTERIOR for 02-05 WRX Interior or STi BangLa TXIC Private Classifieds 5 12-17-2006 06:49 PM
Want to trade 2006 WRX interior for all black WRX interior or STi interior Bala Interior/Dressup/Audio & Security 16 08-18-2006 09:02 AM
Want To Trade 2006 Wrx Interior For Black Wrx Interior Or Sti Interior#pics# Bala South East Region Forum 4 08-18-2006 09:01 AM
Want to trade 2006 WRX interior for all black WRX interior or STi interior Bala Private 'For Sale' Classifieds 21 07-11-2006 11:24 AM
Wanted: 2004 subaru WRX seats, OR STi seats!! Or older STi seats mmmprza Private 'Wanted' Classifieds 2 12-11-2003 03:16 PM
