Welcome to the North American Subaru Impreza Owners Club Monday October 24, 2016
Old 07-15-2008, 10:15 AM   #1
Member#: 38829
Not your usual 1997
Legacy GT
Default Cams + LW Flywheel + LW Pulley = CEL...?
I know this has been somewhat documented in places, but I dropped in the motor I've been working on this weekend. It's got Delta cams with the street grind, LW ACT flywheel, and LW Mr. Josh pulley.
Upon driving the car a little, I first got a P1507, Idle Control System Malfunction. I checked the IAC solenoid and valve and they looked OK, I used the lower mileage one. I cleared the code and reseated the vacuum lines going to the IAC. After driving the car a bit more, I am getting intermittent misfires on three cylinders around 2000 RPM. I need to go pull codes again to see if it's consistent (I only have data from two misfires).
The idle is pretty rough. I expected a little bit of a funky idle from the cams but not this bad. What's wrong?
I'm using the intake manifold, plug wires and coil from my '97 motor, with the heads and block from the '98 motor. I read somewhere that the length of the plug connectors could be slightly different... Should I swap the coil and wires?
Or is the combination of cam, LW flywheel, and LW pulley too much and the ECU is just confused? Or should I look at valve clearances again? I was pretty anal when I adjusted them. Timing was dead on as during the install but I guess it could have skipped a tooth, I've heard of it happening before.
fastenova is offline   Reply With Quote
Old 07-15-2008, 11:15 AM   #2
Member#: 36735
99 GF8 Impreza 2.0
2= 1998 BD + BK Legacy GT
Sounds like a timing issue...
Huffer is offline   Reply With Quote
Old 07-15-2008, 08:43 PM   #3
Member#: 115154
2005 Outback XT
White on grey
check for vacuum leaks. You'll throw codes with the cams, even higher likelihood with the lw parts but idle shouldn't be changed that drastically.
rougeben83 is offline   Reply With Quote
LW Pulleys and LW flywheel combo bad? PhilSine Built Motor Discussion 7 11-06-2007 08:55 PM
LW Flywheel + LW Crank Pulley djosrs Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 10-27-2007 01:07 AM
Exedy LW flywheel vs. Primitive LW flywheel Legacy777 Transmission (AT/MT) & Driveline 5 07-13-2004 06:17 PM
Consensus on LW crank pulley and LW flywheel? Compressed Normally Aspirated Powertrain 23 07-17-2003 01:13 AM
removed lw flywheel, intake, headers, cat last nite wistful Normally Aspirated Powertrain 5 06-18-2003 08:51 PM
