Old 07-14-2008, 10:57 AM   #1
skingfreak
Member#: 152591
2010 Jetta TDI Cup
Jet Black
Default Hyper Flash....
So i did an FX35 projector retro into my stock housings, and everything works good, except i got the awesome hyperflash with the LED turn signals i bought. What would i do with one of these http://www.superbrightleds.com/flashers.htm does it replace the stock replay (where is it located in the car?) or does it just go inline with the turn signals in which case i will need two??
Jon
skingfreak is offline   Reply With Quote
Old 07-15-2008, 11:03 AM   #2
skingfreak
Member#: 152591
2010 Jetta TDI Cup
Jet Black
No one??
Old 07-15-2008, 12:17 PM   #3
ptirmal
Member#: 82243
07' Acura TL-S
They should replace the stock relays... no idea where that is though, sorry...
ptirmal is offline   Reply With Quote
Old 07-15-2008, 04:47 PM   #4
skingfreak
Member#: 152591
2010 Jetta TDI Cup
Jet Black
Thanks^^ Man i might be better off just buying new halgon bulbs, and selling these..
Old 07-15-2008, 08:51 PM   #5
ATX25RS
Member#: 4597
2011 Mitsu Outlander
Sport (Ex-Suby owner X3)
those flashers reeplace the stock one that is located IIRC in the fuse box in the engine bay. you might be better off just getting some load equalizers and placing them in line.
ATX25RS is offline   Reply With Quote
Old 07-15-2008, 11:56 PM   #6
0wrx2
Member#: 82297
you need to add resistance. since the LED draw less amperage than halogens, you need to make up for it but putting a resistor somewhere in the mix.
0wrx2 is offline   Reply With Quote
Old 07-16-2008, 12:20 AM   #7
Handsdown
Member#: 29355
just anywhere in the circuit on the load side.
Handsdown is offline   Reply With Quote
Old 07-16-2008, 10:04 AM   #8
skingfreak
Member#: 152591
2010 Jetta TDI Cup
Jet Black
What size resistor? and is this something i can source from radio shack? (deppending on the size of the resistor)
Old 07-16-2008, 04:12 PM   #9
0wrx2
Member#: 82297
yeah. not sure the exact size you will need but more than likely, you should be able to pick one up at radio shack.
if you could find the resistance of the LED's and halogens I could help you out finding what size resistor you need.
Old 07-16-2008, 05:23 PM   #10
skingfreak
Member#: 152591
2010 Jetta TDI Cup
Jet Black
Yeah i looked on the website, and there were no resistance values like there usually is for a single bulb. And as far as the halgon goes i have no idea
Old 07-16-2008, 07:00 PM   #11
ATX25RS
Member#: 4597
most of the large autopart stores will sell the load equalizers. they usually run about 15-20 bucks for the pair.
Old 07-17-2008, 10:29 AM   #12
skingfreak
Member#: 152591
2010 Jetta TDI Cup
Jet Black
So i just install those inline? or how exactly does that work?
Old 07-17-2008, 12:22 PM   #13
ATX25RS
Member#: 4597
yep, inline. they help the current draw. they heat up a little so i would suggest putting them somewhere with a little ventilation.
Old 07-17-2008, 06:27 PM   #14
skingfreak
Member#: 152591
2010 Jetta TDI Cup
Jet Black
Interesting, thanks man! i will have to pick some of these up this weekend if im not headed to canada.
Old 07-17-2008, 07:06 PM   #15
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
You're better off getting the electronic flasher unit. The equalizers are just low-value, high-wattage resistors that simulate the load of standard bulbs so the old electromechanical flasher works properly and doesn't flash rapidly because it thinks a bulb is burned out.
Using the resistors totally negates the lower current draw advantage of the LED's, and they also generate a lot of heat so you have to be very careful with placement. The flasher is a much more efficient solution.
FS : *NJ* Sun Auto CyberSpeed- Hyper Ground, Hyper Voltage GT & Hyper Force System AWDrifter21 Tri-State Area Private Classifieds 25 03-24-2009 09:46 AM
FS : *NJ* Sun Auto CyberSpeed- Hyper Ground, Hyper Voltage GT & Hyper Force System AWDrifter21 Engine/Power/Exhaust 21 03-24-2009 09:44 AM
Sun Auto - Cyber Speed : Hyper Ground, Hyper Voltage & Hyper Force Systems VVS Engine/Power/Exhaust 29 04-25-2008 01:20 AM
FS: So Cal 2 Sets of Rotas Torque and SDR Hyper Black / Hyper Silver CRXSTI Private 'For Sale' Classifieds 30 06-02-2006 01:48 PM
So Cal: 2 Sets Rota Wheels Torque and SDR Hyper Silver / Hyper Black CRXSTI Private Vehicle 'For Sale' Classifieds 1 04-22-2006 07:48 PM
