Old 07-14-2008, 01:39 PM   #1
ScottKONIG
Member#: 147436
Default 06 wrx cluster in 02 wrx?
Guys Im wondering if you can help me here. I already have searched for a while but Im not coming up with exactly what I am looking for.
I own a 2002 wrx. I also have a 06 WRX cluster, NOT THE STI CLUSTER.
I want to swap it in. I think its going to be close. If worse comes to worse i can get a schematic and figure out but i figured I would check with you all first.
Does anyone have a link to this swap? Im sure its no the same as an 06 sti cluster.
Also any information or direction you could point me to is GREAT!!
Thanks
Scott
ScottKONIG is offline   Reply With Quote
Old 07-15-2008, 12:39 PM   #2
SportyMark
Member#: 167263
02 WRX Sedan
i put a 05 cluster in my 02 it was a direct plug in. Only downside is my mileage is way off.
SportyMark is offline   Reply With Quote
Old 07-16-2008, 12:11 AM   #3
ScottKONIG
Member#: 147436
thanks for the information...the only thing is that the 06 is a newer cluster. It has the outside temp and that additional little window in the bottom left under the fuel/temp gauges.
I wonder if its still plug and play just the temp doesnt work
I guess ill figure it out next week...haha
Any other insight is appreciated
Old 07-16-2008, 09:06 AM   #4
skingfreak
Member#: 152591
2010 Jetta TDI Cup
Jet Black
Why not plug it in and see what happens? it might be P&P but honestly i would attempt to source the schematics online (if you look in the correct places they are free, Don't ask me, i don't have the 02 or the 06)
skingfreak is offline   Reply With Quote
Old 07-16-2008, 09:53 AM   #5
ScottKONIG
Member#: 147436
I will end up just plugging it in and seeing, but electrics are funny. If you cross the wrong wires...you might end up with fried components or just blown fuses.
Old 07-16-2008, 10:42 AM   #6
Uber-Charged
Member#: 154313
2002 /2004 Conversio
n Stage 2 WRB
plug it in and see what happens man! You will have to buy a temp sensor and wire it in order for that to work, but i would just try to see if it would fit! btw you might have to file the far left connector in order to get it to fit dude to the 2 notches. Good luck
Uber-Charged is offline   Reply With Quote
Old 07-16-2008, 08:33 PM   #7
ScottKONIG
Member#: 147436
ok for future reference for anyone else that wants to do this.
Plugs in fine. Works fine. ABS light does stay on like on the other clusters...but a little black tape and it goes away ...haha
The cruise control light doesnt go on with the button but that is probably because my cluster never had that light to begin with...lol
The only thing i notice is that the tach is a bit off at idle...it reads a little lower then actual and so does the temp (from my last cluster)
But thats about it. Oh and the tach seems a bit sluggish when reving from idle...but its all good Im sure my last cluster was prob the same way and just never noticed it.
I hope this helps someone one day..haha
Thanks for all the help.
06 WRX Cluster into 02 WRX - Adding Digital Temp and ABS Fix TheShadowWRX Electrical & Lighting 3 10-13-2009 11:59 AM
06 STi cluster in 04 WRX? logich Electrical & Lighting 0 07-19-2006 04:47 PM
04 sti cluster in 02 wrx will it work? red_rex_02 Interior & Exterior Modification 6 03-27-2006 02:38 PM
can i put a 04,05,06 sti cluster in a wrx? rmontheweb Interior & Exterior Modification 6 11-15-2005 05:15 PM
Electric issue with 04 STi cluster in 02 WRX SubaruWRX2k4 Electrical & Lighting 3 03-28-2005 12:18 AM
