Old 07-15-2008, 01:48 AM   #1
t-wrex
Member#: 74030
02 WRX
Default Help w/ knock sensor
I have a Zeitronix WBO2 and it has an feature to log aux. sensor data 0-5v. I was hoping that I could monitor the knock signal with this. There are 2 wires @ the ecu for the knock sensor. 1 is called "signal" and reads 2.8 v the other is called "shield" and has 0v. I taped in to the signal wire and the Zeitronix unit reads a constant 2.8v even when knock occurs. Do I tap the "shield" wire instead? I guess I don't understand how the knock sensor reports knock to the ECU.
t-wrex is offline   Reply With Quote
Old 07-16-2008, 10:24 PM   #2
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
The knock sensor is a piezio elecrtric device. As it detects vibrations from a misfire it sends out a frequency signal. It isn't a DC level change.
HELP!!!!! P0325 Knock sensor on my Legacy 2.5 VOLTIS5 Normally Aspirated Powertrain 3 03-24-2009 03:20 AM
help! which knock sensor 2.5 or 2.0? WRB04 Service & Maintenance 2 10-30-2007 03:20 PM
Help, need knock sensor MDRex Mid Atlantic Impreza Club -- MAIC 0 01-15-2007 05:09 PM
HELP replacing knock sensor timmui Normally Aspirated Powertrain 3 12-17-2004 03:07 AM
Need info/help - Forester Knock Sensor cboggess Forester Forum 1 08-06-2004 07:44 PM
