Old 07-15-2008, 12:54 AM   #1
davedaman77
Member#: 177385
08 2.5i
SSM
Question Bov Question??
I'm buying a BOV for my turbo set up.. I really want to get a SSQV because they sound amazing!! Are their any real cons to having one or are they better than the piston designed?
Now, what confuses me is that on all the listings like on egay say that the valve springs are adjustable. How would I know how tight or loose my spring should be?
And then does the vacuum line just go to anywhere on the intake manifold? Let's say my break booster line? Would that be a good place to tap into?
Sorry, hope this isn't to dumb/noob of a question. I just want to be 100% certain before I start hacking up lines on the scooby.
Dave
davedaman77 is offline   Reply With Quote
Old 07-15-2008, 10:29 AM   #2
davedaman77
Member#: 177385
08 2.5i
SSM
This is the, "someone please help me bump."
Old 07-15-2008, 10:58 AM   #3
'93Impreza1.8T
Member#: 171092
1993 Impreza 1.8T
Dave
i have the ssqv and i really like it take a look at my build. the only con that i could think of is that if u place thebov after the maf it will not idle mine is open at idle and cause the car to bog, if placed before the maf than it is no problem. my set up is a blowthrough type maf though and fmic. the ssqv opens at idle closes when u give it gas then opens to let out any boost pressure once the throttle plate is closed. you adjust the spring to your liking with the screw on the back of the bov the harder setting is for those with higher boost pressures. and for ur last ? the vacuum i used for the bov was T'd to the fitting after the throttle plate so it has manifold vacuum the best source i think. well hope this helps.
http://forums.nasioc.com/forums/show....php?t=1553509
'93Impreza1.8T is offline   Reply With Quote
HKS SSQV BOV Question...Not another BOV thread o2sys General Community 6 09-17-2010 07:04 PM
VTA BOV Question and Catch Can Question...Kinda Urgent FocusdSound Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 06-16-2008 10:14 AM
Modding a BOV ~ A different type of BOV question Sausage Newbies & FAQs 38 08-07-2006 05:40 AM
BoV Question... DannyGT Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-10-2001 09:44 AM
BOV question imprezive General Forum Archive 6 10-15-2000 04:53 PM
