Old 07-15-2008, 12:36 PM   #1
attitude
Member#: 52043
04 sti
Default what determines thrust bearing location?
the block, or the crank?
attitude is offline   Reply With Quote
Old 07-15-2008, 04:20 PM   #2
BiGtUrBo
Member#: 126022
block.
BiGtUrBo is offline   Reply With Quote
Old 07-16-2008, 11:45 AM   #3
charliew
Member#: 125304
Both the crank and block. ph1 is #3 main and ph2 #5
charliew is offline   Reply With Quote
Old 07-16-2008, 01:06 PM   #4
attitude
Member#: 52043
04 sti
how can you tell phaze one and two?
Old 07-16-2008, 01:40 PM   #5
charliew
Member#: 125304
As I said ph1 has the thrust on #3. Ph2 has it on the rear #5. I think I read where some replacement cranks may be machined for both.
Do a search for thrust bearing locations.
Old 07-16-2008, 02:25 PM   #6
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
IIRC new OEM cranks are machined for thrust in both #3 and #5 now.
Funny that I have never bothered to notice and check. I will on the next new crank I grab.
Old 07-16-2008, 07:04 PM   #7
attitude
Member#: 52043
04 sti
i just ordered a new crank, which is why i was asking.... i think i remember my block was a #3, but cant look because it is at the machine shop. which was why i was stressing.
Old 07-16-2008, 09:36 PM   #8
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Phase 1 motors have 48mm rod journals wheras phase 2's have 52mm journals. You should be able to check your rods/bearings for that without the crank on hand.
Old 07-16-2008, 10:30 PM   #9
Homemade WRX
Member#: 33782
96 bastard child
that's only true for an EJ25 crank...just specifying incase someone searches this thread in the distant future...
Old 07-17-2008, 03:42 AM   #10
Kosmic
Member#: 99140
GD Racing chassis
Slowly in construction
2006 STI crank in a 22T block and I have 0.013" walk. No go.
Kosmic is offline   Reply With Quote
Old 07-17-2008, 08:24 AM   #11
attitude
Member#: 52043
04 sti
ok, but all the rods are the same; its the bearing thickness that will make it 48 or 52 correct? because if i ordered a new crank, and will have to get new rods i will bang my head on the wall.
Thrust Bearing location 5hif73r Built Motor Discussion 1 01-09-2009 08:10 PM
location: thrust bearing on crank vs. thrust bearing on block kiwee Built Motor Discussion 21 04-25-2008 08:56 PM
EA71 thrust bearing jjamzman 'Old School' Subaru Forum 2 08-10-2004 10:48 PM
Does STi have the updated thrust bearing yet? dinofx Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 14 01-10-2004 10:11 PM
Lookin for misc info, Are there any true 360 Thrust Bearing turbo options for the WRX sherifx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 10-29-2002 06:00 PM
