Old 07-15-2008, 09:16 PM   #1
EJ18S
Member#: 177098
95 Legacy L AWD
Maroon
Default Turbo water pump on EJ18 ?'s
Well, Im slowly but surely collecting parts for my EJ18T build on my daily driver and have noticed a nice oil leak from the front cover of the engine.
Im sure its the oil pump seal or front crank seal so I'm just going to crack it open and repair them both.
Question is, since Im in there I might as well repair the timing belt and replace the water pump.
Since Im going turbo in the near future I'd like to replace the water pump with a turbo pump since Im going forced induction anyway.
1. Should I use the EJ22T water pump or the EJ20T pump from an '03 WRX?
2. Am I going to require any different coolant hoses from a turbo model to mate up with my stock EJ18 motor/coolant system?
3. Anything else you guys can recommend?
Thanks,
EJ18
EJ18S is offline   Reply With Quote
Old 07-15-2008, 11:21 PM   #2
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
The only point in using a turbo water pump would be if you were going to add the oil cooler. You will need different coolant lines. There are two extra bungs on a turbo water pump. One is for the cooler and the other one is for the overflow tank. Depending on how you are doing your turbo set up and cooling it, you could potentially use all factory parts to make this happen.
And an Ej22t and Ej205 water pump are pretty much the same.
If you need help pulling together the hard lines and a coolant tank let me know. I have all of them. I may also have an oil cooler as well but I would have to check.
Old 07-15-2008, 11:56 PM   #3
turboL
Member#: 111735
96 Legacy2.0GTSOLD
Bimmer Tech
The other point to using a turbo water pump is that the WRX/STi exhaust manifold doesn't fit with teh stock waterpump without some crazy rad hose routing.
turboL is offline   Reply With Quote
WRX water pump on 2.2 turbo swap? steven_esworthy Normally Aspirated with bolt-on Forced Induction Powertrain 2 04-29-2007 11:17 AM
Return to turbo water pump? mxpunk Normally Aspirated with bolt-on Forced Induction Powertrain 0 04-12-2007 12:14 PM
Ej20G Oil Cooler / legacy turbo water pump / oil pump supermoose Private 'For Sale' Classifieds 2 09-29-2005 12:06 PM
Legacy Turbo Water Pump/housing White 2.5rs Private 'Wanted' Classifieds 1 10-22-2003 01:19 PM
EJ Turbo VS EJ non Turbo water pump DJIMPREZA Normally Aspirated with bolt-on Forced Induction Powertrain 3 04-29-2002 03:36 PM
