Old 07-16-2008, 01:04 AM   #1
Jericho
Member#: 108248
2006 WRX
Default Wheel Fitmit over STi Brembos
Hey guys, I might have posted this thread in the wrong section but I have been doing a ton of research and cant find the answer. I am installing STi Brembo brakes on my 2006 WRX this weekend. I am worried that the stock 17" wheels wont fit over the brakes.
I am wondering if anybody has had any experience or fitmit issues with the stock 06' WRX wheels over a larger brake set? I am trying to avoid buying spacers, as I have not read too many good things about them, but I also like the stock wheels and would like to keep them. But before I get too far into this, I would like to know early on if I need spacers or not so that I can get them ordered before I tear down my brakes.
Thanks for your help guys.
-Robbie
Jericho is offline   Reply With Quote
Old 07-16-2008, 07:12 AM   #2
mav1c
Hoodbridge!
Member#: 560
2006 STi, '11 A4
Crystal Gray, Silver
The stock '06 WRX wheels will NOT fit over the Brembos. You'd need a pretty big spacer, which would also require longer wheel studs. Really, you should just get wheels that fit over the Brembos, so budget that into your brake upgrade. Here's a question, why do you want to upgrade? The stock 4/2 pots on the '06 are decent brakes.
Old 07-16-2008, 09:54 AM   #3
Tomas26
Member#: 150648
2007 WRX
Blouch inside :D
Just get other set of rims that clears brembo's. I will do brembo swap in the future too and will put new rims
Tomas26 is offline   Reply With Quote
Old 07-16-2008, 12:27 PM   #4
ButtDyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 05 Saabaru
Check the brakes/suspension forum, brake supersticky, brembo FAQ. There's a list of wheels that clear in there.
ButtDyno is offline   Reply With Quote
Old 07-17-2008, 11:45 AM   #5
Jericho
Member#: 108248
2006 WRX
I test fit them last night...you guys are right, the spokes wont clear the calipers. I am going to need at least a 10mm spacer from the measurements I took. So that will have to do until I save enough for new wheels .
I am doing this upgrade because I track the car and have a few very nice back roads in my area, and the stock brakes work great, but for the amount of heat generated at the track my rotors are having issues. Originally I was going to only upgrade to Stop Tech rotors, new pads, and SS brakelines. But I came across a deal for these I couldnt pass up, as I havent spent too much more money on this upgrade than I would have doing the just the rotors and pads.
-Robbie
Will Tenzo DC6 wheels fit over sti brembo brakes? bugeyes Tire & Wheel 0 05-24-2008 06:27 PM
BBS RGR Wheels (17x7.5, +48) fit over STi Brembos? Wrinkleboi Brakes, Steering & Suspension 22 03-13-2007 05:59 PM
Would 17" LGT rims fit over STi Brembos? Prodrive PFF7 ? Alan l. Brakes, Steering & Suspension 6 03-16-2006 10:25 AM
Anyone have Volk SE37K 17"x8.5" ET50 over STi Brembos? Evil STI Tire & Wheel 1 08-16-2005 11:29 PM
18 X 8.5 over STi Brembo salaki Texas Impreza Club Forum -- TXIC 21 10-07-2004 08:49 PM
Message Board Statistics All times are GMT -4. The time now is 07:08 AM.
