Old 07-16-2008, 06:46 PM   #1
AutoBahn
Member#: 113022
2006 Impreza WRX TR
Crystal Gray Metallic
Default How to replace OEM fog light bulbs on 2006 WRX?
Does anyone know where I can find a procedure for replacing the OEM fog light bulbs on a 2006 WRX? The bulbs I am installing are:
Narva Rangepower+50 H3 55w
Thanks!
AutoBahn is offline   Reply With Quote
Old 07-16-2008, 07:10 PM   #2
bobanoid
Member#: 153096
2007 WRX limited
urban gray metallic
not sure if theres a diy, but if u go under your car in front of ur tires u remove two or three plastic tabs and pull out the liner/cover (its attached to the front of hte bumper, then u can access it pretty easily.
bobanoid is offline   Reply With Quote
Old 07-17-2008, 10:53 AM   #3
bzbuzz
Member#: 116052
2011 STI ( Sold )
^^^ very easy..
and make sure not to touch the bulb glass surface...
bzbuzz is offline   Reply With Quote
Old 07-29-2010, 09:22 PM   #4
STAT1
Member#: 136709
2006 WRX Sedan Ltd.
Stage - 2
Sorry to res but...
I popped the plastic font piece off the bumper, now how do I get to the bulb? Thanks
STAT1 is offline   Reply With Quote
Old 07-30-2010, 09:36 AM   #5
Big-E
Member#: 123843
2016 STI LTD CWP
Let LED's light your way!
Remove the two bolts holding the assembly in place and pull the assembly out and then unhook the harness.
Once the assembly is free from the vehicle, you can then remove the back cover to access the bulb.
How do I change H3 fog light bulbs on 2003 WRX? scoobbee Interior & Exterior Modification 9 03-24-2013 08:50 PM
How to access fog light bulbs on '09 OBS Eric91Z Interior & Exterior Modification 4 04-29-2010 03:14 PM
How do I change the fog light bulbs on an 04 WRX? salvooch Electrical & Lighting 2 10-14-2004 10:54 AM
Fog Light Bulbs on '04 WRX winsor311 Electrical & Lighting 13 07-27-2004 10:03 AM
