View Poll Results: How many items have you had serviced
No items in 36,000 miles 22 36.07%
One item in 36,000 miles 9 14.75%
Two items in 36,000 miles 4 6.56%
Three items in 36,000 miles 8 13.11%
Four items in 36,000 miles 1 1.64%
Five or more items in 36,000 miles 17 27.87%
Voters: 61. You may not vote on this poll
Old 03-06-2002, 05:57 PM   #1
Apisatrox
Member#: 9523
2005 WRX STi
Rally Ridge Blue
Question How many items have you had your Sub Serviced for?
In the standard period of 36,000 miles, how many items have you had repaired under warrenty?
Apisatrox is offline   Reply With Quote
Old 03-06-2002, 06:17 PM   #2
CosmoTheCat
Member#: 3409
1996 OBS
Green.
My HVAC fan made a squeaking noise on the low settings. They replaced it, and it now makes a knocking noise. So far it's one item replaced for free... but it needs to be one item replaced twice.
On my '98 L I had the same squeak, but Kirkland Subaru told me it was leaves in the vent system () and they'd have to charge me to fix it. But they did flush the tranny/diff when the grease melted and ran out the splines onto the exhaust.
All in all... two cars, three "problems", 60k miles... not bad I'd say.
CosmoTheCat is offline   Reply With Quote
Old 03-06-2002, 06:19 PM   #3
Julian
Member#: 1182
MY00 RS
BRP
0 in ~26K miles. I had the O2 sensor recall, but that's the only time it has been into the dealer's service bay.
Julian is offline   Reply With Quote
Old 03-06-2002, 06:26 PM   #4
Apisatrox
Member#: 9523
2005 WRX STi
Rally Ridge Blue
I just ask because in 26,000 miles I had:
Indicator light for fog lights (fuse), O2 Sensor, Trim on passenger and driver side door not put on properly (window was catching on anti-theft peice), when car was cold RPMS @ 3000.. way too high - fixed, power locks stopped working..
just wonder what i have instore for me for the next 10k miles.. glad I got the 0 decutable 100,000 warrent right now
Old 03-06-2002, 08:49 PM   #5
GRWRX
Member#: 4129
2002 WRX sedan
They replaced the seat cover after my massive butt wore through the material.
GRWRX is offline   Reply With Quote
Old 03-06-2002, 11:07 PM   #6
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
my 2001 RS has had:
inner axle seal gone bad
new clutch
new wiper blades
fix squeak/loose spring near firewall
CE light which was a bad coil (#3)
i think that's it... in one year... 32k miles...
hey, no car is perfect!!!
Jamie
www.subiegal.com
Old 03-07-2002, 02:49 AM   #7
dannyboy7
Member#: 5432
2006 Spec Beezie
Had the WRX for almost one year, and just took it in to have the "performance gauge pack" replace cause the turbo gauge isnt calibrated and the volt gauge sticks. 27000 miles.
dannyboy7 is offline   Reply With Quote
Old 03-12-2002, 02:54 PM   #8
Apisatrox
Member#: 9523
2005 WRX STi
Rally Ridge Blue
Only 21 votes?
We can do better than that
Old 03-15-2002, 09:31 AM   #9
rlarose
Member#: 7550
2002 WRX Sedan
was PS, is now WRB
Here is a run-down from my spread-sheet I keep in my 8,000 miles of car ownership:
Problem Days @ Suabru Mileage
Purchase 0 148
Rear Differential 7 150
O2 Sensor 1 2301
Transmission 30 7214
Clutch Problem 0 7321
Clutch Problem 0 7380
Clutch Problem 0 7412
Clutch Problem 6 7650
Clutch Attempt 1 8 8000
Clutch Attempt 2 6 8016
Everything has been deemed "defective" and replaced under warranty. They are in the process of replacing my car or refunding my money now.
UPDATE: After 54 down days, getting my old car back. BUT, Subaru is looking to replace it with a spanking new one.
rlarose is offline   Reply With Quote
Old 03-15-2002, 10:25 AM   #10
gtguy
Member#: 2184
2005 Legacy GT wagon
Platinum Silver Metallic
1) that weird flap rattle in the wagon
2) an ECU reflash to rectify the false code glitch
The end. I might suggest that the low number of responses means that (horrors!) these cars are actually reliable.
Kevin
gtguy is offline   Reply With Quote
Old 03-20-2002, 03:49 PM   #11
Apisatrox
Member#: 9523
2005 WRX STi
Rally Ridge Blue
Old 03-20-2002, 05:56 PM   #12
WRXDude
Member#: 3576
1886 Benz Motowagen
Let me see-
4 visits before 300 miles - CE lights. The cause? A hose had fallen off (it was too short), causing a false PO457. Guess who finally fixed it - me!
1 visit to ECU reflash due to false CE's (not related to above)
1 visit to fix glovebox door broken by the dealer
1 visit to finally fix the glovebox door broken by the dealer
7 Visits in 10k miles. Groan. But the last 5k have been trouble-free, so lets hope that the earlier issues were out of the ordinary.
WRXDude is offline   Reply With Quote
Old 03-20-2002, 08:19 PM   #13
gertman
Member#: 16530
2004 WRX STI
WR Blue
I have an 02 WRX with 2,300 miles. I have been to the dealer once, but it was only a SMALL problem:
Fresh from the factory to my greedy little hands the light for the rear license plate was not working.
Has anyone else had this problem? Has anyone thought to check? Anyway, it only took took the friendly Subaru 3hrs to fix it.......but hey I got a free wash!!!
The culprit, a loose connector fixed under warrenty!!!
gertman is offline   Reply With Quote
Old 03-20-2002, 08:36 PM   #14
Gumpy
Member#: 15722
2003 EVO
Default Number of items replaced
Items fixed or replaced in 11,000 miles
Door and trunk latch adjustments
2Check engine lights for cylinder 1 and 3 misfires
CPU re-flashed
2 visits to dealer for drivetrain deceleration noise.
Dealer currently working on replacing drivetrain components, after I showed them some i-club members fixes.
Gumpy is offline   Reply With Quote
Old 03-20-2002, 10:07 PM   #15
kaboom
Member#: 6160
2009 Legacy
Gray
1. air conditioner
2. check engine light
3. brakes
kaboom is offline   Reply With Quote
Old 03-21-2002, 09:15 AM   #16
jamz
Member#: 8725
2013 Black Company
Annalist
Nothing until this morning, when most of my power steering fluid gushed out onto the ground for some reason. :-/
I have the decel noise, but it is pretty faint, not sure if I'm going to have them look at it. I'd want to take the kartboy out before doing that.
jamz is offline   Reply With Quote
Old 03-22-2002, 02:15 PM   #17
Apisatrox
Member#: 9523
2005 WRX STi
Rally Ridge Blue
Does the 26% for 5+ times in 36,000 miles seem REALLY high to anyone else?
Old 03-23-2002, 12:27 AM   #18
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
No, because this is light-years away from being at all a random and scientifically valid survey.
Old 03-31-2002, 02:46 AM   #19
IMPREZive 02 WRX
Member#: 11436
1999 Impreza RS
eBay racing edition!
5 in 8,700 miles
IMPREZive 02 WRX is offline   Reply With Quote
How many times have you had sex with no form of contraceptive? Christoff Off-Topic 67 09-22-2007 11:18 AM
Have you had your H6 upgrade for a while? If so how has the rotor held up? Drew888 Brakes, Steering & Suspension 7 04-04-2005 07:37 PM
How many "partners" have you had? incorporeal Off-Topic 176 08-19-2004 03:00 AM
Women: how many orgasms have you had in a row? Orson Off-Topic 4 10-16-2003 10:45 AM
Poll- How many nails have YOU had in your tires? fuzzbox General Forum Archive 21 10-20-2000 09:54 AM
