Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Gauges & Electronics
Closed Thread
Old 07-17-2008, 01:42 PM   #1
201Motorsports
Vendor
Vendor Sales Rating: (37)
Member#: 121809
2003 Evo VIII
Default 201 Motorsports Interior Gauge Sale! Defi & AEM IN STOCK!
Defi BF Imperial Amber and White Gauges @ 201 Motorsports
Imperial
Defi-Link Meter BFs are electronic blacked out gauges which are high response and refined design. When the car is off they have a black face with no numbers on them. As soon as the car is turned on, the gauges light up and are in full affect.
Defi-Link Meter BFs need to be connected to Defi-Link Control Unit II. Up to 6 gauges can be connected and controlled by one Control Unit II. The name of the connection system is "Defi-Link System." Defi-Link System allows gauges to be attached to Defi-Link Control Unit II with a single "DAISY CHAIN" wiring system.
Control Unit II: $99 shipped
Defi BF Imperial Amber 60mm Gauges
Boost: $210 shipped
EGT: $245 shipped
Fuel Pressure: $245 shipped
Oil Pressure: $245 shipped
Oil Temperature: $184 shipped
Water Temperature: $184 shipped
Defi BF Imperial White 60mm Gauges
Boost: $210 shipped
EGT: $245 shipped
__________________
[b]Phil
[COLOR="SeaGreen"]201 Motorsports[/COLOR]
[COLOR="SeaGreen"]Email[/COLOR]
phil[at]201motorsports.com
[center]
[/b][/center]
201Motorsports is offline
Old 07-17-2008, 01:44 PM   #2
201Motorsports
Vendor
Member#: 121809
2003 Evo VIII
Defi BF Amber and White Gauges @ 201 Motorsports
Metric
Defi BF Amber 60mm Gauges
Boost: $210 shipped
EGT: $245 shipped
Defi BF White 60mm Gauges
Boost: $210 shipped
EGT: $245 shipped
__________________
[b]Phil
[center]
[/b][/center]
Old 07-17-2008, 01:44 PM   #3
201Motorsports
Vendor
Member#: 121809
2003 Evo VIII
Defi Red Racer, White Racer, and Blue Racer Gauges @ 201 Motorsports
No Control Unit Needed!!!
Exclusive gauges for the USA which are derived from quick-responsive and high-accurate Defi analog gauges.
* Stepping motor "STEP MASTER VS-2" provides smooth operation
* Ignition ON initiates self-luminescence gauge
* Red illumination using high-brightness LEDs
* Full 270 degrees sweep dial provides ultimate visibility
* A mounting bracket and instrument case is provided with the product
* The red triangle of the regular position bezel can be used as a warning indicator
* Does not require the Defi-Link Control Unit for use (Blue Racer Gauge cannot be connected to the Defi-Link System)
Self-diagnostics function monitors both sensor disconnection and short-circuiting during startup.
Sensor disconnection check:
This function reports any in-proper connections, broken or disconnected sensor or sensor wire. The pointer will wave between 250 and 260 degrees.
Short-circuiting check:
This function indicates any short circuit on the sensor or sensor wire.
__________________
[b]Phil
[center]
[/b][/center]
Old 07-17-2008, 01:45 PM   #4
201Motorsports
Vendor
Member#: 121809
2003 Evo VIII
__________________
[b]Phil
[center]
[/b][/center]
Old 07-17-2008, 01:45 PM   #5
201Motorsports
Vendor
Member#: 121809
2003 Evo VIII
AEM UEGO @ 201 Motorsports
AEM UEGO Wideband O2 52mm Gauge
This is a six-in-one gauge-type UEGO controller.
AEM’s Gauge-Type Wideband UEGO Controller features an LED readout and sweeping LED “needle” that changes colors as AFR changes from rich to lean. The unit’s 52mm (2-1/16”) gauge housing fits in most gauge pods and can be remotely mounted virtually anywhere.
No laptop required for monitoring!
Key features of the AEM Gauge-Type UEGO Controller:
* 24 Color-coded LED display lights provide immediate reference to engine’s air/fuel ratio (AFR) or Lambda (11.0:1 to 17.0:1)
* Integrated three-digit display reveals AFR or Lambda in real time (10.0:1 to 18.5:1)
* User-selectable 0-5v analog output included for use with data loggers and most programmable engine management systems
* Switch between AFR or Lambda readout with a twist of a switch (included face plate change is required for proper readout)
* Included black and silver bezels, black and white AFR gauge faces and black Lambda gauge face allow you to personalize the look of your gauge!
* Quick-Connect system eases installation by allowing users to mount the gauge and sensor wiring separately
* Ideal AFR monitoring tool for carbureted applications and engine dynamometers
* Does not oscillate AFR like narrow band sensors
* Serial data stream included for output of AFR (RS 232)
* Accurate to 0.1 AFR
* Bosch UEGO sensor included
Price: $218.11 shipped
__________________
[b]Phil
[center]
[/b][/center]
Old 07-17-2008, 01:45 PM   #6
201Motorsports
Vendor
Member#: 121809
2003 Evo VIII
AEM Tru-Boost @ 201 Motorsports
AEM Tru-Boost 52mm Gauge Type Boost Controller
The AEM Tru-Boost Boost Gauge/Controller combination is a mult-featured system for simplified, comprehensive boost control. Packaged within a 52mm gauge are a 29psi capable boost controller, peak-memory boost gauge. Other features include overboost alarm and overboost shutdown, wastegate delay for faster spool up, and a driver for an external warning lamp.
NOTE: This unit includes black and silver bezels and black and white faceplates for simple color selection and easy matching to other AEM gauges (i.e. serial gauge, UEGO, etc.)
Features:
* 52mm (2 1/16") Complete stand-alone boost controller gauge
* On-board pressure sensor included for boost levels up to 29 PSI
* Two user selectable units
* Peak boost memory
* User selectable over boost alarm with overboost shutdown
* User scaleable bar graph display
* User selectable waste gate delay for quick turbo spool
* External warning lamp driver
* No external interface required for programming
* Easy to install harness allows for quick and easy installation
* Boost hose and fittings included for easy hookup to on-board pressure sensor
* Multi-Bezel system: includes silver and black bezels, white and black face plates
Price: $302 shipped
__________________
[b]Phil
[center]
[/b][/center]
Old 07-21-2008, 08:11 AM   #7
mav1c
Hoodbridge!
Member Sales Rating: (52)
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
Can you still get, ot have, the older Defi 52mm Link gauges? I need a replacement for my 52mm Oil temp gauge. Black face, white lettering, lights up green with red dial.
Will the new BF gauges work with the older Link Control Unit?
mav1c is offline
Old 07-22-2008, 03:59 PM   #8
201Motorsports
Vendor
Member#: 121809
2003 Evo VIII
The LINK series are long gone unfortunately I don't have any left either. The new BF gauges will work with the older Control Unit, however (Part #: DF05001)
__________________
[b]Phil
[center]
[/b][/center]
Old 08-11-2008, 12:21 PM   #9
201Motorsports
Vendor
Member#: 121809
2003 Evo VIII
Bump it up
__________________
[b]Phil
[center]
[/b][/center]
Old 08-12-2008, 10:32 AM   #10
201Motorsports
Vendor
Member#: 121809
2003 Evo VIII
Up to the top!
__________________
[b]Phil
[center]
[/b][/center]
Old 08-12-2008, 04:16 PM   #11
mav1c
Hoodbridge!
Member#: 560
Cool. Going to order the 60mm White oil temp gauge. Don't suppose you have this?
MB 60mm Single Gauge Pod for WRX/STI:
mav1c is offline
Old 08-12-2008, 04:45 PM   #12
201Motorsports
Vendor
Member#: 121809
2003 Evo VIII
Actually I definitely could get that for you I'm going to give you a call
__________________
[b]Phil
[center]
[/b][/center]
Old 08-12-2008, 04:50 PM   #13
mav1c
Hoodbridge!
Member#: 560
Bah. I guess I jumped the gun and ordered it with the Defi mount kit. I just missed your call, but got your message. Can't call back right now, but if you can take off the Defi mount kit and add on the MB pod, that'd be cool. I'll try to call in about 1/2 hour.
mav1c is offline
Old 08-12-2008, 04:53 PM   #14
201Motorsports
Vendor
Member#: 121809
2003 Evo VIII
No prob at all I'll swap them out no problem... if you can't call back, it's no big deal. I'll get it all sorted out.
__________________
[b]Phil
[center]
[/b][/center]
Old 08-14-2008, 04:45 PM   #15
201Motorsports
Vendor
Member#: 121809
2003 Evo VIII
In stock bump
__________________
[b]Phil
[center]
[/b][/center]
Old 08-15-2008, 09:27 AM   #16
201Motorsports
Vendor
Member#: 121809
2003 Evo VIII
Sweet gauges! BUMP!
__________________
[b]Phil
[center]
[/b][/center]
Old 08-17-2008, 09:46 AM   #17
201Motorsports
Vendor
Member#: 121809
2003 Evo VIII
Bump it up to the top!
__________________
[b]Phil
[center]
[/b][/center]
Old 08-18-2008, 01:53 PM   #18
201Motorsports
Vendor
Member#: 121809
2003 Evo VIII
Woo, bump
__________________
[b]Phil
[center]
[/b][/center]
Old 08-19-2008, 03:47 PM   #19
201Motorsports
Vendor
Member#: 121809
2003 Evo VIII
Gauges
__________________
[b]Phil
[center]
[/b][/center]
Old 08-20-2008, 12:52 PM   #20
201Motorsports
Vendor
Member#: 121809
2003 Evo VIII
Up to the top!
__________________
[b]Phil
[center]
[/b][/center]
Old 08-21-2008, 11:50 AM   #21
201Motorsports
Vendor
Member#: 121809
2003 Evo VIII
Gauges
__________________
[b]Phil
[center]
[/b][/center]
Old 08-21-2008, 11:58 AM   #22
201Motorsports
Vendor
Member#: 121809
2003 Evo VIII
Up
__________________
[b]Phil
[center]
[/b][/center]
Old 08-22-2008, 11:01 AM   #23
201Motorsports
Vendor
Member#: 121809
2003 Evo VIII
Thank you for the orders!!
__________________
[b]Phil
[center]
[/b][/center]
Old 08-23-2008, 05:32 PM   #24
201Motorsports
Vendor
Member#: 121809
2003 Evo VIII
Gauges YESSSS!
__________________
[b]Phil
[center]
[/b][/center]
Old 08-27-2008, 12:21 PM   #25
201Motorsports
Vendor
Member#: 121809
2003 Evo VIII
Awesome gauges
__________________
[b]Phil
[center]
[/b][/center]
Closed Thread
Driveline Motoring /// STRI & Defi Gauges & Pods *IN STOCK & ON SALE* DriveLineSales Gauges & Electronics 39 06-18-2009 02:29 PM
The 201 Motorsports "There's A Defi & AEM Price Increase Coming 01/01/09" Sale 201Motorsports Gauges & Electronics 4 12-24-2008 10:32 AM
201 Motorsports Interior Gauge Sale! Defi & AEM IN STOCK! 201Motorsports Interior/Dressup/Audio & Security 20 08-23-2008 12:05 PM
$$LOOK$$ DEFI Blue Racer Gauges + DEFI Link Display **IN STOCK & READY TO SHIP** Kami Speed Gauges & Electronics 7 05-21-2008 11:28 AM
Defi Gauges, Tein, & Blitz in stock Gruppe-S Interior/Dressup/Audio & Security 11 05-03-2005 06:01 PM
