Old 03-06-2002, 08:08 PM   #1
Evan J. Kelly
Forever Scooby Newbie
Member#: 11172
2000 GC8 RS Coupe'
FlatBlack&BlueRidge Pearl
Default CEL P0304 - Cylinder 4 Misfire Detected
not on my car, my bros wrx.
all he has is a k&n drop-in and a mbc set at about 18psi...what could cause that???
Evan J. Kelly is offline   Reply With Quote
Old 03-06-2002, 08:17 PM   #2
eclipsefire
Member#: 5203
2002 Impreza WRX
Sedona Red Pearl
Overboost maybe?
Nick
eclipsefire is offline   Reply With Quote
Old 03-06-2002, 08:19 PM   #3
BluSuby
Member#: 12154
04 Sti
99 Outback
I don't know but I've had the same thing happen in cylinder 3 and I have the same mods. I have mine set at 15 psi for the winter though. Did his car misfire in the morning when it was cold out and not up to full operating temp yet? My friend seems to think, and I agree, that with the higher boost and cold dense air getting forced in the engine that in some instances it's blowing the spark out ( the gap is too large).
Like i said I've had this happen, but it was when the car was under full boost and the intake air temp was still pretty cold. I wouldn't worry unless it happens often. I just stay out of the bosst until the car is warmed up more and the intake air temp is up. It never happens then,
Bryan
BluSuby is offline   Reply With Quote
Old 03-06-2002, 08:20 PM   #4
wackie
Member#: 14580
2004 Forester XT
www.wrxhackers.com
18psi, good lord. Drop that to 15.5 or so and reset your ECU. The car should be noticeably faster.
wackie is offline   Reply With Quote
Old 03-06-2002, 08:24 PM   #5
BluSuby
Member#: 12154
04 Sti
99 Outback
I agree. Does he have an EGT gauge? Running that kind of boost in the winter time, is asking for trouble. When I'm under full boost with cold intake air temp, my EGT's will fly past 1600 F. Cars love cold dry air.
Bryan
Old 03-06-2002, 09:32 PM   #6
AK'S REX
Member#: 12163
Jesus, 18 PSI!! WHat the hell kind of car do I have?
To calm the confusion, it's set at about 16 or so. I do not yet have an egt gauge, although I can tell you I never let any significant amount of boost build up at partial throttle. Believe me, I take extreme care in keeping it well under 10 psi at anything less that full or very near full throttle.
Yes, it's kinda cold here, but not cold enough to do this, I've driven in colder weather with no probs.
I 80% of the time fully warm the car up before driving, the other 20% I will baby it untill at optimum temp. verified by not only my coolant gauge, but by the oil temp as well. Anyhow, I've reset the ecu twice, and both times it's come back within 10 minutes of driving. The car right now is noticeably slower, idle's very rough and occasionally surge's under acceleration.
So what's the prob? I haven't really checked anything out in detail yet, aside from pulling the code. Plug's?? Coil pack?? I'm going to check a couple of things out tonight, and see what I can come up with. Any suggestions?
AK'S REX is offline   Reply With Quote
Old 03-06-2002, 09:45 PM   #7
BluSuby
Member#: 12154
04 Sti
99 Outback
I would start with the plugs first. Maybe just pull them and close the gap a little and see if it runs any better. If that doesn't work buy some new ones and try it. After that I don't know. My car has only misfired twice. The 1st time it threw a CEL. The 2nd time I could feel it hesitate and I let off the gas to prevent it from misfiring. Try the plugs and let me know how you make out,
Bryan
Old 03-06-2002, 09:45 PM   #8
Evan J. Kelly
Member#: 11172
2000 GC8 RS Coupe'
The thread starter was Jim logged on under my name and not me...
thanks Jim.:monkey:
Old 03-07-2002, 12:06 AM   #9
tokigiracing
Vendor
Member#: 15567
hush up billjohn
tokigiracing is offline   Reply With Quote
Old 03-07-2002, 12:42 AM   #10
kensington
Member#: 9113
2k4 WRB STi
RIP#92 Fred"G-Money"Zippy
sounds like it's time for an ECU reflash. I've gotten 3 misfires on 3 and 1 on 4 but I've been hearing that they are still sending the chips away to be re-flashed and I don't feel like being w/o just yet.
kensington is offline   Reply With Quote
Old 03-07-2002, 07:39 PM   #11
IMPREZive 02 WRX
Member#: 11436
1999 Impreza RS
eBay racing edition!
They reflashed my ECU a while ago, and no CELs since. I got the car back same day too. Dropped it off before work, and picked it up at lunch!
IMPREZive 02 WRX is offline   Reply With Quote
Old 03-07-2002, 07:56 PM   #12
BamBooI
Member#: 10945
2006 Evolution IX
They probably just reset the ecu in yours. They are suppose to be sent off. Unless they had some "in stock" and they just switched out.
BamBooI is offline   Reply With Quote
Old 03-07-2002, 07:58 PM   #13
IMPREZive 02 WRX
Member#: 11436
1999 Impreza RS
No, I'm sure they reflashed it...SOA is less than a mile down the road from my dealer. I've had about 6 or 7 CELs on the previous ECU.
Old 03-07-2002, 07:59 PM   #14
AK'S REX
Member#: 12163
The resflash sounds interesting. However, how would I know(or the dealer for that matter),if it need's a reflash? Something could very well be f'd up, I don't know as of now.
Anyhow, I'm gonna go check the plugs.
Old 03-08-2002, 12:10 PM   #15
wrxtremeWGN
Member#: 12281
08 FSXT
Tiger's Blood
i had the same thing happen to me yesterday. misfire in 3rd cylinder. the car was semi-cold and i jumped on it out of a parkinglot shifted to 3rd and let the car decelerate and at about 4k rpms i popped the cel. went to the dealer today had the code read and i was told everything was 100% fine. no problems yet well see though, these cars are very quirky.
wrxtremeWGN is offline   Reply With Quote
P0302 Cylinder 2 misfire detected...help! RS_to_WRX_swap Normally Aspirated Powertrain 52 03-28-2011 11:46 PM
p0304 cel cylinder 4 misfired fujiwara_yingyu Normally Aspirated Powertrain 12 07-12-2007 07:28 AM
P0303-P0304 Cylinder 3 & 4 misfire detected =( Hunt3r Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 10-09-2005 03:57 PM
CEL P0304 - cyl 4 misfire, want people's thoughts edkwon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 08-19-2004 05:44 PM
