Old 07-18-2008, 06:14 AM   #1
joekerk
Member#: 155250
Default Engine oil loss when high Rev to 8000rpm
Anyway to prevent engine oil from loss when high Rev to 8000rpm boost a 26psi? around 480whp on a 2.5 bulid with forged piston n rod ?
joekerk is offline   Reply With Quote
Old 07-18-2008, 07:07 AM   #2
Storm
Member#: 5218
96L Most Over-
Developed Beater
Use a catch can. And vacuum it out of the IC and intake manifold....you might not have filled it up enough to see the smoking yet.....but you will eventually.
Jay
Old 07-18-2008, 09:30 AM   #3
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
A few things that will help:
sump with windage tray
highflow/high-pressure oil pump
high-quality oil
wrxsti.l is offline   Reply With Quote
Old 07-18-2008, 09:56 AM   #4
bluescoobywagon
Member#: 14911
Not A Wagon!
2011 WRX - 285s on 18x9.5
Set up a GOOD catch can with a drainback and you should cut the consumption down.
bluescoobywagon is offline   Reply With Quote
Old 07-18-2008, 10:47 AM   #5
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
I have been told that not rev'ing to 8000 rpm at 26 psi helped as well.
mick_the_ginge is offline   Reply With Quote
Old 07-18-2008, 12:25 PM   #6
MS WRX
Member#: 117780
2004 WRX
+10000
MS WRX is offline   Reply With Quote
Old 07-18-2008, 02:59 PM   #7
MartinSTi05
Member#: 145145
2006 wrx STi
Sounds like you are also likely to have an "engine bearing loss" at those RPMs.
MartinSTi05 is offline   Reply With Quote
Old 07-18-2008, 10:03 PM   #8
Member#: 111556
2006 STI
sounds like the car is moving out....
+1 on windage tray, and return catch can
xerox445@yahoo.com is offline   Reply With Quote
Old 07-21-2008, 11:16 AM   #9
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
You will always have some oil consumption but tell us how much you are loosing. Is it 1 quart every 3k miles or are we talking 1 quart every track session?
One quart or less every 3k miles of normal driving is acceptable. In racing conditions our engines typically will loose 1/4 of a quart or less (pushed into catch can) at 30 psi for 15-20 minutes of WOT road racing with rpms up to 8200 (when using our Competition Catch Can). This amount of loss would be considered normal given the engine build and use.
I would say you could get away way with 1/2 quart per track session but using our Competition Catch Can would cut that in half but if you are using more then really it's a motor build issue due to excessive blow by.
Phil
www.elementtuning.com
Element Tuning is offline   Reply With Quote
Old 07-21-2008, 11:57 PM   #10
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
I could sooo see that coming!
jigga is offline   Reply With Quote
Movement when not in gear w/ high revs RallyIt07 Transmission (AT/MT) & Driveline 4 11-02-2009 10:53 AM
What engine oil to use in high HP engines crazy06 Built Motor Discussion 11 10-07-2009 10:35 AM
Loss of power at high REV Jlude Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 10-20-2007 08:19 PM
When is a good time to measure engine oil? m u f a s i s Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 01-21-2004 03:55 AM
engine sputtering at High Rev full throttle app. outback bosco Service & Maintenance 3 01-26-2002 10:17 PM
