Old 07-18-2008, 08:00 AM   #1
Craig A.
Member#: 122519
2005 Legacy GT Wagon
Default 2004 WRX Headlight Socket Part Number?
I went to subaruparts.com and was unable to find the part number for the metal low beam socket (for the H1 bulb) for a 2004 WRX. The part is attached to the headlight assembly using two screws. The clip that holds the bulb in is also attached to this metal part. There also appears to be a grounding wire attached to the socket.
When I was replacing a bulb, the small hook that the clip goes underneath broke (cheap metal )
Any help would be greatly appreciated.
Craig A. is offline   Reply With Quote
Old 07-18-2008, 08:50 AM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Individual parts of the headlight assembly are not available separately from Subaru, they will only sell you the complete unit. Your options are- junkyard, used headlight(s) from the classifieds, or fabricating your own replacement parts.
Old 07-18-2008, 09:54 AM   #3
Craig A.
Member#: 122519
That seems to be the case. I just called a dealership and its part of the headlight assembly. Its unfortunate that it is not sold seperately. Thanks for the information though! I will have to fab something up.
2004 fog light bulb part number??????? tweekernyc Electrical & Lighting 1 12-22-2004 06:18 PM
2004 USDM OEM injector part number ? StiDreams Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 03-29-2004 08:30 PM
wrx intercooler elbow part number inpreza kid Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 01-27-2002 08:36 PM
headlight assembly part number slide Legacy Forum 2 01-21-2002 11:58 PM
wrx exhaust manifold part number? jasony Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-09-2001 05:32 PM
