Old 07-18-2008, 05:05 PM   #1
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
Default My mFactory / DS1 5spd install diary
I though I'd document the whole process as I swap in a mFactory gearset built by DS1 Motorsports.
So
DAY 1
Tranny brought home
What's in the wrapping:
I'm gonna start with getting the car in the air a bit. Mine is really low so I"m starting like this:
I'm planning on using wooden boxes in the back to hold up the car for extra sturdyness
A couple of hours later (it took a couple of hours because my jacks suck (GM jacks) and the car is low, thus i have no leverage on the lever.
But here's what I got so far:
I'm not planning on doing all the work like this, just the basics till I start taking out the axels and such .
More tomorrow
Bad Noodle is offline   Reply With Quote
Old 07-18-2008, 05:34 PM   #2
wrxjrk
Member#: 164093
COOL.. My MFactory1-4 trans should be in on mon or tuesday..
wrxjrk is offline   Reply With Quote
Old 07-18-2008, 06:43 PM   #3
jonpark
Member#: 141449
2007 EvoIII16g WRX
UGM EJ257+05/6speed
do you have DS1's phone number?
jonpark is offline   Reply With Quote
Old 07-18-2008, 06:53 PM   #4
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
http://ds1motorsports.savidtech.com/...ntact&Itemid=3
Old 07-18-2008, 07:09 PM   #5
DS1
Vendor
Member#: 111780
DS1 is offline   Reply With Quote
Old 07-18-2008, 08:24 PM   #6
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Don't jack the car by the rear differential.
Old 07-18-2008, 08:32 PM   #7
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
Why, those are the "scoobymods approved" jacking points:
Old 07-18-2008, 08:35 PM   #8
gto7419
Member#: 44256
05 outback xt
02 wrx wagon - crushed :(
Why not?
gto7419 is offline   Reply With Quote
Old 07-18-2008, 08:50 PM   #9
mugenXP
Member#: 155272
2006 WRX
Panda AE86
how much did everything cost you?
mugenXP is offline   Reply With Quote
Old 07-18-2008, 09:05 PM   #10
Decon
Member#: 108453
2015 legacy
dude I jack up army 35k lb trucks on the axles. I think he will be fine there.
Decon is offline   Reply With Quote
Old 07-18-2008, 09:13 PM   #11
ciper
Member#: 15543
90BJ Legacy LS ABS
Jacking a Subaru by its rear differential damages the bushings and can bend part of the subframe. It is a "free floating" part which is neither directly attached to the suspension or the body. Subaru SPECIFICALLY says not to jack the car by this location.
"scoobymods approved" doesnt mean much. Do you believe everything you read on the internet
Don't take my word for it though. Get the FSM from any EJ series Subaru and look at the assembly of the rear subframe and differential.
Yes your 35k lb truck normall supports its weight on the axle. The Subaru does not
Old 07-18-2008, 09:15 PM   #12
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
^ alright
So how do you get the back up onto jackstands?
You can't do it 1 side at a time
and:
widely used diagram:
Old 07-18-2008, 11:16 PM   #13
mugenXP
Member#: 155272
2006 WRX
Panda AE86
if subaru says to not jack it by the rear differential, i would not jack it by the rear diff, no matter what some online diagram says.
Old 07-19-2008, 10:33 AM   #14
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
DAY 2
Time to get into this, so starting with the engine:
Downpipe, IC pipes, pitchstop, harnesses, and ground removed:
Starter removed:
Slave cylinder removed:
1st ?
The instructions say to pull this pin after removing the starter and slave cylinder:
it's for an 02/03 which has a push type clutch
The 07s have a pull type and I don't see that pin
Do I still need to release the fork?
Old 07-19-2008, 12:36 PM   #15
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
inside take nappart
raised to super height and drained tranny fluid
started prying axle
removed bottom bolt
took suspension appart
as far as I can get the axle out
well I'm kinda stuck... dunno how to take the axles out. This is as far as I can get them after taking apart the suspension
I hope they'll have enough clearnce to get out once I move the tranny back
Old 07-19-2008, 12:55 PM   #16
DS1
Vendor
Member#: 111780
Unbolt the sway bar endlink, it will allow you to push the arm further down to get the axle out. Take the outer joint out of the hub first then out of the trans.
You can put your shifter back together, take the bolt out of the joint on the trans, also you will want to put your stock shifter back in or an SPT short throw, we've had issues with the Kartboy shifters popping out of first
There is no release for pin on 06'-07's because of the push style clutch.
-Dylan @ DS1
Old 07-19-2008, 01:19 PM   #17
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
-Dylan @ DS1
Thanks for the info. I'm not sure what you mean by "take the outer joint out of the hub"
Do you mean unbolt the giant bolt on the hub? or do you mean the bolt underneath with the cutouts?
Also, I was pulling on the axle really hard and some found some circular spring wrapped around the axle. Is that anything to worry about?
Old 07-19-2008, 02:04 PM   #18
gto7419
Member#: 44256
05 outback xt
The axle is connected to the car in two spots - to the tranny and to the hub (where the wheel is bolted on) - If you take the axle nut off and remove the WHEEL side of the axle first it makes it easier to take the axle out of the tranny.
Old 07-19-2008, 02:13 PM   #19
DS1
Vendor
Member#: 111780
Old 07-19-2008, 03:16 PM   #20
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
Ok, so took the rear diff cover off and undid the first 2 bolts,
Then I couldn't get to the other two, so I lifed the car, roateted wheels, and got the other 2 facing down, marked position before I took off the driveshaft
Took the shifter linkage off
I don't have a tranny jack, so I used some enginutiy:
The tranny is now all unbolted and ready to come down:
I can't get the front axle nut off since I don't have a socket big enough. I can't get the ball joint off either since I don't have a seperator.
So the plan is to move the tranny back slowly until I can wiggle the driveshafts out once they have enough clearence
Old 07-19-2008, 03:23 PM   #21
2007bluewrx
Member#: 157798
2007 wrx for sale!!
BLuE
dude thats soooo sweet. Thanks for the good write up so far. I am saving up for a gear set, but don't know which one I need. Good luck!!
2007bluewrx is offline   Reply With Quote
Old 07-19-2008, 03:34 PM   #22
DS1
Vendor
Member#: 111780
^^ PM me
Good to see you've almost got it out.
Remember to support the engine with a jack before you seperate the trans
-Dylan @ DS1
Old 07-19-2008, 03:40 PM   #23
Rasmusson14
Member#: 77658
2004 ej207, ppg dogs
3" green, ITS ALL 4 SALE!
Or just a nice 2X4
And the slide technique works like a champ and I've never had to remove or undo any suspension components.....although I have axle stubs which my make this easier.
Nice pics and write up.
Rasmusson14 is offline   Reply With Quote
Old 07-19-2008, 05:23 PM   #24
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
getting the tranny out isn't as bad, just a lot of cardio.
What I did was basically "wiggle" the tranny loose using 2 jacks.
1. Supporting the tranny
1. jacking up the engine by the crosspipe
So what I would do is jack 1 up, pull on a bar I had wedged between the tranny and the cross member, jack other up, pull, lower first, pull, lower second pull
Did that a good 10 time and everything came apart just fine.
The axles were easy to get out once the tranny was loose.
My biggest question are about the clips on the ends of the axles... anything wrong with them being a lit loose?
The other thing I'm not sure about is this bracelet made out of a spring... it came somewhere off the tranny and I'm not sure what it's supposed to do...any input about these would be appreiated
Old 07-19-2008, 05:27 PM   #25
DS1
Vendor
Member#: 111780
that sping is part of the seal.
Having issues with my MFactory gearset... SonicYeller Transmission (AT/MT) & Driveline 7 05-04-2010 11:57 AM
Install Diary 02BlueSuperRoo Car Audio, Video & Security 34 12-18-2007 10:29 PM
FYI - My '00 LGT 5spd Wagon is for sale Rice & Gravy Legacy Specific Parts 2 06-06-2006 08:37 AM
What can I do to beef up my 94 Impreza 5spd transmission? STi gears? Who has them? lotus2843 Transmission (AT/MT) & Driveline 10 03-04-2005 02:19 PM
Will the auto (a/t) ecu from 92 legacy turbo work in my 94 impreza 5spd? lotus2843 Subaru Conversions 2 01-12-2005 09:31 PM
