#1 |
Member#: 90483
Vehicle:06 450 whp sti UGM |
i have an 06 sti with a few mods (gt 30r etc.)
it does about 450 whp stock internals (suck) and i just found out that my #2 piston is cracked and the car also eats about a quart of oil a week (daily driver) im trying to find out what are my options besides getting a new short block. thanks for all the help.
#2 |
Member#: 180815
Vehicle:I want 2 be like Gen "me" gimme $ please!? |
how many miles?
what needs to happen is the heads have to come off, pistons come out and the cylinders inspected and measured. If ok, buy some CP/JE pistons and have the cylinder's honed. Install new rings and put it back together. However, I would strongly suggest splitting the block apart and inspecting the bearings........especially if the block has any mileage. How long has the 30r been on it? You have detonated so either you got a bad tank of gas, and/or your timing needs to be lowered another degree or so. |
#3 |
Member#: 145145
Vehicle:2006 wrx STi |
I will buy your damaged block, to help subsidize your new one, lol.
#4 |
Member#: 90483
the car has 30,000 miles the upgrde was done at about 4,000 miles
and from what i understand that the upgrade has nothing to do with that the shop where everything been done at reasures me that they have stock cars cracking pistons. so im lost for words (do the subie stock engine suck that much?) |
#5 |
Member#: 90483
#6 |
Member#: 180815
that's cause the stock cars are detonating!
![]() do you realize what you're asking? you got 26k out of the STOCK engine that was designed for 300hp.........and you're running it over 500hp. If I were you, i'd quit bitching and count my blessings. |
#7 |
Member#: 115420
Vehicle:It's like a STI but it doesn't break= EVO |
^^^^^^^ exactly........anything over 400whp for a DD you are playing with fire. To get that many miles out of your stock block is pretty good.
#8 |
Member#: 55147
Vehicle:2004 STi PSM |
#9 |
Member#: 12811
South East
Vehicle:2002 2.5l Wrx 517whp/516wtq (Stage pi) |
I had that happen to me and I needed to fix it on the cheap. I did all the work myself so I saved on labor. Took 6 hours from start to finish and I was back on the road.
I bought 4 new pistons for 50 shipped Rings 130 had to buy a complete set 1 head gasket 32 2 cam seals 12 I sold the extra pistons and rings and got all my money back. Ended up costing 0. |
#10 |
Member#: 60142
Vehicle:2011 WRX Grey |
#11 |
Member#: 155358
Vehicle:2008 Forester Steel Silver |
^^I would guess take offs from some ones new Sti short block that got a set of drop in pistons.
#12 |
Member#: 125144
SCIC
Vehicle:2005 wrx STi wrb |
#13 |
Member#: 12811
South East
#14 |
Member#: 130276
NESIC
Vehicle:2004 Pontiac GTO LS1 T56 RWD |
#15 | |
Member#: 55147
When I pulled the plugs the side electrode had made contact with the center electrode. What is odd is that upon inspection of the piston through the spark plug tube, the top of the piston looked fine. We had no clue what hit the plug, or if something did, as there was not obvious contact marks anywhere. I put new plugs in the car, cleared the codes/reset ECU and started it up. It ran smooth and the codes didn't reappear. I drove the car for about two miles and upon pulling into my neighborhood I gave it a rev and all hell (and the top of the piston) broke loose. We heard metal pass through the exhaust which is strange as the turbo is in perfect shape. ![]() Oh well. |
#16 |
Member#: 55147
I guess I'll post the other pictures so people can see what we saw:
![]() ![]() Original plug from MISFIRE code. I wish I had a picture of the top of this side electrode. There is no obvious marks from any contact. ![]() Second plug from cylinder#4 that was eaten alive. Obvious how this got to this condition. ![]() ![]() |
#17 |
Member#: 55147
And Dave, sorry for jumping in on your thread. I didn't mean for it to turn into a discussion about MY motor.
#18 | |
Member#: 54918
If we were to build you a motor for instance and you left your tune as is then it would likely suffer the same fate but just a long slow death. The piston might not fail but it would pound your bearings pretty good. A built engine is going to take some pretty severe detonation before it self destructs but it can fail just the same. Welcome to the "I broke my stock piston club" ![]() Thanks, Phil www.elementtuning.com |
| Thread Tools | |
| Display Modes | |
| So I just found out that I am renting an apartment... or so my vm's have been saying | Sephro | Off-Topic | 3 | 11-09-2004 10:18 AM |
| I just found out that I will be back in time for Rally Mexico...Who's going? | bildo | Texas Impreza Club Forum -- TXIC | 1 | 12-28-2003 07:49 PM |
| Help! Just found out that I am short one tire for the track on 5/22, anyone have? | ZMANNH25rs | New England Impreza Club Forum -- NESIC | 2 | 05-21-2003 09:59 AM |
| Just found out that our legacy is... | warlord225 | Legacy Forum | 11 | 04-02-2003 04:46 PM |
| Just found out that i have speed vision! | Tim Sanderson | Mid West Subaru Owners Club Forum -- MWSOC | 16 | 04-03-2002 08:33 AM |
