Old 07-19-2008, 08:27 AM   #1
talvai
Member#: 136358
2006 WRX Limited
6mt/5x114/vf43/S204
Default Question on Hid
I did a retrofit with lightwerkz to get s2000 hid retrofit and paint. Right now I have the negative on the negative section of the battery and the positive on the positive of the battery. I just want to make sure this is the best place to put those or should I put it somewhere else?
talvai is offline   Reply With Quote
Old 07-19-2008, 03:15 PM   #2
GeoffSFAs10
Member#: 173996
your better off attaching the negative to the body on another ground, and not the negative of the battery
GeoffSFAs10 is offline   Reply With Quote
Old 07-22-2008, 10:59 AM   #3
skingfreak
Member#: 152591
2010 Jetta TDI Cup
Jet Black
That will work just fine, or you can ground to the chassis. that being said, i have my ballast wire harness wired just like that for over two years with no issues. I say leave it!
skingfreak is offline   Reply With Quote
Old 07-23-2008, 01:36 AM   #4
subaru3169
Member#: 55252
* pullup bar *
that's fine.. unless you need the room on your posts for more stuff
subaru3169 is offline   Reply With Quote
Old 07-23-2008, 09:06 AM   #5
skingfreak
Member#: 152591
2010 Jetta TDI Cup
Jet Black
Even than you can take car of it with a simple grounding kit, they're cheap, don't look half bad, AND best of all, you don't have to go around drilling holes in your engine compartment!
Quick question on HID Wiring CRL1084 Electrical & Lighting 7 06-03-2006 07:19 AM
quick question on hid and power vennt Electrical & Lighting 3 10-20-2004 12:57 PM
Thoughts/Questions on changing JDM HIDs to LHD, and wiring HIDs. Kwyjibo Interior & Exterior Modification 14 08-30-2003 11:02 PM
Urgent!!! question on HID JDM headlights AmirWRX Bay Area Impreza Club Forum -- BAIC 1 12-31-2002 06:58 PM
Quick question on hyper white high beams and fog lights to match HIDs IA Performance Interior & Exterior Modification 7 10-05-2002 06:02 PM
