Old 07-19-2008, 11:13 AM   #1
ray101381
Member#: 131327
2013 2014 BMW M5 CP
BMW Individual LSB
Default Beatrush Propeller Shaft mounts
has anyone used these or have them on their car currently. it sounds like a good idea in theory but wanted to see if they actually made a noticeable difference. they are the machined aluminum mounts that replace the stock rubber mounts, here's a picture for reference, courtesy of rallysportdirect.com
ray101381 is offline   Reply With Quote
Old 07-19-2008, 11:29 AM   #2
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
I don't think anyone has them. Unless they are cheap, it seems like a really silly mod to me.
Old 07-19-2008, 01:06 PM   #3
DS1
Vendor
Member#: 111780
I have used them in our race cars, for the $30ish dollars the cost they work pretty well.
They do transmit a lot of noise into the cabin.
-Dylan
DS1 is offline   Reply With Quote
Old 07-19-2008, 01:32 PM   #4
ray101381
Member#: 131327
2013 2014 BMW M5 CP
BMW Individual LSB
did the driveline feel any different aside from the noise? a more solid connected feeling? thanx again
Old 07-19-2008, 02:13 PM   #5
DS1
Vendor
Member#: 111780
A little more solid
Old 07-19-2008, 09:02 PM   #6
axelthrasher
Member#: 144779
200X ZOMG a car 100%
crabon fibre girlfrendorz
Why won't these fit the 02/03 WRX? It says in the description that they only fit 04 and up.
axelthrasher is offline   Reply With Quote
Old 04-08-2010, 01:53 AM   #7
DriftIt
Member#: 137388
'05 WRX
Reviving an old thread after doing a little research (and yes, this thread was found using the search button ) but not finding much info on this mod. Can anyone shed some light on whether or not these are worthwhile and make any difference whatsoever in driveline movement? I know the driveline carrier bearing sits inside a rubber bushing and takes most of the shock from the driveline but I'm wondering if there's any improvement in on/off throttle response. I'm contemplating getting them since I've got all control arm bushings and rear diff/subframe bushings and lock bolts ordered and on the way from TiC. Just trying to tighten up some of that driveline/drivetrain slop. TIA
DriftIt is offline   Reply With Quote
Old 04-09-2010, 01:33 AM   #8
pauli18c
Member#: 174553
2005 STi 360whp
345wtq on 93oct @ 20psi
i have them and you cant tell at all that they're there. that doesnt mean they arent doing anything, you just cant feel them like other bushings/mounts.
pauli18c is offline   Reply With Quote
Old 04-09-2010, 05:07 AM   #9
DriftIt
Member#: 137388
'05 WRX
Got it. Seems like most vehicles have the carrier bearing bracket bolted straight to the underside of the car without any sort of bushing anyways so I would imagine NVH isn't much different. Oh well... one more item I'll probably get to sooth the mod bug
Old 06-30-2010, 02:16 PM   #10
Zulu-
Member#: 232213
I have them, easy install on a lift with a BFscrewdriver to get off the factory mounts. With the factory mounts there is up/down play in the driveshaft at that position, after beatrush's I couldn't move it down at all.
Probably placebo, but I felt WOT was smoother.
Zulu- is offline   Reply With Quote
Old 07-03-2010, 09:44 AM   #11
Pacobeagle
Member#: 8775
2010 "Zed" 1000
Orange/White
I'll post up after getting my ride back on the road. I don't have the Beatrush units....I got mine from www.Importimageracing.com. They have the same thing available.
Jose
Pacobeagle is offline   Reply With Quote
Old 07-04-2010, 02:30 AM   #12
*03wRx*
Member#: 128417
2004 Fast tuned
470hp/550tq FordLightning
-Dylan
A little more solid
pretty much hit it on the head. I have these as well
I have a 03 and they fit...
*03wRx* is offline   Reply With Quote
Old 07-04-2010, 09:21 AM   #13
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Here's what makes no sense about this part. Get under the car and shake the driveshaft right where that joint is. It moves soooooo much inside that carrier bearing that those little things will do nothing. Even you make that little mount solid the entire driveshaft will still move an inch in either direction. It's all a placebo effect.
Tony
Old 07-04-2010, 10:09 AM   #14
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
Tony
I agree completely. I've been thinking this the whole tome this threads been active.
Old 07-04-2010, 12:20 PM   #15
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
Aspen White / Silver
1 Piece drive shaft solution.
Token-Negro is offline   Reply With Quote
Old 07-04-2010, 05:18 PM   #16
69subaru360
Member#: 159682
1995 WRX
2015 F150
I used a few thick flat washers in place of the rubber bushings. I noticed no difference good, bad, noise or otherwise.
Old 07-04-2010, 06:01 PM   #17
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
That's gangsta, but you get 95% of the use with -95% of the cost.
Old 07-05-2010, 12:30 PM   #18
hoffmanEstates
Member#: 122043
04 wagonier
psm
i think its just something to dump money into. i have them and all it takes away is the slight slop you have on the carrier bearing.
hoffmanEstates is offline   Reply With Quote
Old 07-05-2010, 04:16 PM   #19
bzbuzz
Member#: 116052
2011 STI ( Sold )
i doubt this part does anything... IMO... wasting money...
bzbuzz is offline   Reply With Quote
Old 07-05-2010, 07:48 PM   #20
Member#: 67
1999 Outlasting
the competition.
Tony
Clint and i talked about this a few years ago, The CNC lathe was sitting pretty for a little bit. We both figured out that its pretty much a useless bling part. So we didnt bother making any. Save your pennies for gas.
T
Old 07-05-2010, 10:19 PM   #21
1breel
Member#: 189314
2002 GGSTi
01G
I'm with Token on this, 1-pc drive shaft and just do away with the whole thing.
1breel is offline   Reply With Quote
Old 07-05-2010, 10:39 PM   #22
hoffmanEstates
Member#: 122043
04 wagonier
psm
+1 do a price effective shaft like alum. and a "high"end shaft CF or Ti
Old 07-07-2010, 07:40 PM   #23
fastwrx25
Member#: 126441
03 bugeye
I have the torque solution shaft mounts. very subtle difference if at all, not so great bang for buck.
I agree on the driveshaft, I want one eventually.....I just wish we had more choices for driveshafts other than the aluminum dss and acpt cf one. Other than going to your local driveshaft shop.
fastwrx25 is offline   Reply With Quote
New Beatrush propeller shaft mounts-$50 shipped byroll01 Suspension/Brakes/Handling 2 07-07-2009 01:54 PM
Spacer in propeller shaft mount SurfGuruJeff Transmission (AT/MT) & Driveline 0 06-27-2008 07:56 PM
STi Drive Shaft, Propeller Shaft ETC.. Bad Wagon Private 'Wanted' Classifieds 7 09-27-2004 10:25 AM
Propeller shaft compatability?? Wrx Vs. GC8 sube151 Transmission (AT/MT) & Driveline 7 11-23-2003 02:16 PM
Questions about propeller shaft FederalAuditor Transmission (AT/MT) & Driveline 4 05-14-2003 11:31 PM
