Old 07-19-2008, 12:30 PM   #1
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
Default How do I remove lower camber bolts? (Ingalls)
After an hour of trying, I've all but given up.
What is the trick to removing aftermarket camber bolts fron the lower hole of the front suspension? I can't for the life of me get them to come out. It's already loose, but the lobe seems to be caught on something. Is there an orientation for the upper/lower bolt needs to be in order for it to slide out?
Any help is appreciated.
Superorb is offline   Reply With Quote
Old 07-19-2008, 12:39 PM   #2
00LGTP
Member#: 172618
1995 EJ253/D25 GC
371hp/355tq 1.5xtr 93oct
use a big ass breaker bar.
00LGTP is offline   Reply With Quote
Old 07-19-2008, 12:41 PM   #3
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
No no no, it's already loose, but the lobe seems to be getting stuck on something. Is there some orientation the top/lower bolt needs to be in order for it to slide out?
Old 07-19-2008, 12:53 PM   #4
blahhblahh
Member#: 86659
2005 WRX Sedan
WR Blue
sounds to me like the lobe is caught on the strut/hub connection. I would try removing the upper bolt so that you can jiggle the hub around some more. I would say have a friend push on one side while you rotate the bolt. At some point around the turn it should pop out.
blahhblahh is offline   Reply With Quote
Old 07-19-2008, 01:05 PM   #5
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
Tried that already, no luck. The other side just popped out with a hammer. I've tried with the top bolt in/out, someone pushing/pulling and me turning the lobe slowly while whacking with hammer. Every possible combination. I even tried sticking a jack underneath to raise it a few mm to no avail. These things are going straight into the garbage once they're out.
Old 07-19-2008, 01:13 PM   #6
mla163
Member#: 104922
2013 BRZ
try putting something in the upper hole (screwdriver) to take the load off the lower bolt. It should come right out
mla163 is offline   Reply With Quote
Old 07-19-2008, 01:14 PM   #7
MasterKwan
Member#: 98961
2003 WRX
It's not that hard, you just need to get the angle correct. I'd stick the upper bolt back in to help line things up. Then figure which direction the cam is pointed (rotate the bolt) then work the bolt so the camless side is against the strut bracket. It needs some delicacy, not a hammer.
Old 07-19-2008, 02:00 PM   #8
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
I tried the delicate method all morning, but in the end the hammer worked best. Both are now out. Key was to put the stock in the top at full negative, then rotate the lower for full negative camber as well. Left side came out real easily, it was the right side that put up a fight.
Thanks for the help guys
How do I remove lower camber bolts? (Ingalls) Superorb South East Region Forum 12 07-20-2008 04:05 PM
How do you remove aftermarket camber (eccentric) bolts? SSLegacyGT Brakes, Steering & Suspension 3 03-29-2008 04:58 PM
'05 STI front caliper removal--lower camber bolt obstruction? tracks Brakes, Steering & Suspension 2 09-03-2006 10:17 PM
How do you use the camber bolts? jhong567 Brakes, Steering & Suspension 7 04-21-2003 05:01 PM
How do I remove the bottom bolt on the strut? whiterabbit Brakes, Steering & Suspension 15 06-28-2002 08:45 PM
