Welcome to the North American Subaru Impreza Owners Club Tuesday September 1, 2015
South East Region Club
Go Back   NASIOC > NASIOC Regional Areas > South East Region Forum
Old 07-19-2008, 12:45 PM   #1
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
Default How do I remove lower camber bolts? (Ingalls)
After an hour of trying, I've all but given up.
What is the trick to removing aftermarket camber bolts fron the lower hole of the front suspension? I can't for the life of me get them to come out. It's already loose, but the lobe seems to be caught on something. Is there an orientation for the upper/lower bolt needs to be in order for it to slide out?
Any help is appreciated.
Superorb is offline   Reply With Quote
Old 07-19-2008, 02:03 PM   #2
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
I tried the delicate method all morning, but in the end the hammer worked best. Both are now out. Key was to put the stock in the top at full negative, then rotate the lower for full negative camber as well. Left side came out real easily, it was the right side that put up a fight.
I'm going to steer clear of these in the future since I just don't fare well against them. I'll just have to shell out for some camber plates if I want more camber.
Old 07-19-2008, 06:58 PM   #3
cucamelsmd15
Member#: 122980
2010 F150, 2013 CX-5
92 Miata 15 TTF/PTF/E3
Meh, I change mine out on a regular basis. The trick Ive learned is to turn the bolt so the lobe faces down. Then take the BFH to it, comes out like a champ.
cucamelsmd15 is offline   Reply With Quote
Old 07-19-2008, 08:47 PM   #4
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
I got it out with the BFH, but I think I turned the arrow to neg camber. Oh well, I have a new hate for those stupid things.
Old 07-19-2008, 10:13 PM   #5
mofugga
Member#: 19540
2000 old skool RS
BRP
mine are stuck in too!!!!!
mofugga is offline   Reply With Quote
Old 07-19-2008, 11:56 PM   #6
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
Someone else said to point the arrow of the cam straight down with the stock bolt up top, then whack with the hammer.
Old 07-20-2008, 08:35 AM   #7
gotsol
Member#: 17346
08 Cayman S
mine were stuck as well. I took off the rotor to get better access to hit the bolt with a hammer (leave the nut one the end though.) That did the trick
gotsol is offline   Reply With Quote
Old 07-20-2008, 02:23 PM   #8
bl_easy
Member#: 91407
Ver. 2 WRX STi wagon
BRetty green
say no to bolts, get plates
bl_easy is offline   Reply With Quote
Old 07-20-2008, 02:35 PM   #9
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
In a world where money grew on trees
Old 07-20-2008, 02:45 PM   #10
cucamelsmd15
Member#: 122980
Or where commonly available plates would work with your struts
Old 07-20-2008, 03:15 PM   #11
bl_easy
Member#: 91407
BRetty green
money does grow on trees, you just need to know how to get it
this is why i no longer run bolts
I did not hit anything. I was making a u-turn in a parking lot. I was behaving.
i don't run plates either because it's not in the budget. back to OEM for me. I miss -2.5 for the autocrosses... that wasn't enough, but the degree-and-a-quarter I've got now is garbage
Old 07-20-2008, 03:31 PM   #12
rek888v2
Member#: 71287
S202 + 04 STi + 02
WRX
^^^^ Thats hot!
rek888v2 is offline   Reply With Quote
Old 07-20-2008, 04:05 PM   #13
Safir
Member#: 3873
. Paradise is
like Disney with hookers
I used a BFH
bolt was siezed to the hub, wouldn't turn or go in or out, we took teh hub completely out and held it and the strut on the ground while we pounded on it.
WRX sedan A-arms, custom length lateral links, and front camber plates and I have -3 deg on all four corners with no aftermarket camber bolts and the stock bolt in the "neutral" position (01 coupe) Never feared a failure ith the aftermarket bolts, they were just a pain to deal with.
Safir is offline   Reply With Quote
How do I remove lower camber bolts? (Ingalls) Superorb Brakes, Steering & Suspension 7 07-19-2008 02:00 PM
How do you remove aftermarket camber (eccentric) bolts? SSLegacyGT Brakes, Steering & Suspension 3 03-29-2008 04:58 PM
'05 STI front caliper removal--lower camber bolt obstruction? tracks Brakes, Steering & Suspension 2 09-03-2006 10:17 PM
How do you use the camber bolts? jhong567 Brakes, Steering & Suspension 7 04-21-2003 05:01 PM
How do I remove the bottom bolt on the strut? whiterabbit Brakes, Steering & Suspension 15 06-28-2002 08:45 PM
