Old 09-21-2006, 12:11 AM   #1
PARANOID56
Member#: 22035
2003 Brocoma DCab
71 FJ40, 13 DRZ400SM
Default The ol LED switch o roooo
Decided to switch out some of the stock bulbs for some white LEDs. most turned out great, and others, well, are just too dim. See for yourself. All pictures were taken with the same settings for each setup.
Plate Lights
bulb
LED
Front Headligh bulbs
Dome lights
PARANOID56 is offline   Reply With Quote
Old 09-21-2006, 02:21 PM   #2
Rapid_Roo
Member#: 31511
03 GD2 95 GM4
www.ITNRally.org
what type of LEDs did you use?
Rapid_Roo is offline   Reply With Quote
Old 09-21-2006, 04:17 PM   #3
PARANOID56
Member#: 22035
2003 Brocoma DCab
its a new type of LED light.
White High Power
12 VDC Wedge Base bulb (194/168 type)
With High Power Pure White LEDPolarized
I got them over at www.superbrightleds.com
Old 09-23-2006, 06:06 PM   #4
coil222
Member#: 62091
2003 911 Turbo
in the 1st pair of pics did you just replace the license plate lights, or did you replace lights inside of the tails as well?
coil222 is offline   Reply With Quote
Old 09-24-2006, 12:04 PM   #5
PARANOID56
Member#: 22035
2003 Brocoma DCab
just the plate lights. am working on doing the tails soon
Shane
Old 09-24-2006, 02:35 PM   #6
Yesitsdrew5310
Member#: 95182
2005 Impreza 2.5 RS
Silver w/ JDM Roof Vent
Do they have a bit of a blueish tint? I replaced mine a year ago with "white LED's" and I got pulled over by a cop saying they were too "blue" Only my luck huh? But yeah if they are more whiter now and not blue I might get some, I'm tired of replacing those damn licence plate light bulbs.
Yesitsdrew5310 is offline   Reply With Quote
Old 09-24-2006, 05:23 PM   #7
PARANOID56
Member#: 22035
2003 Brocoma DCab
mine have no bluish tent to them. looke just damn white to me
Shane
Old 09-24-2006, 05:33 PM   #8
Handsdown
Member#: 29355
the interior bulbs look really dim to me.
Handsdown is offline   Reply With Quote
Old 09-24-2006, 07:12 PM   #9
PARANOID56
Member#: 22035
2003 Brocoma DCab
well, if you read the post you would have seen that i said that
but yea, that was one of the few that didnt work out right. but i am working on fixing that. got some other ideas up my sleves. they do look cool at night though
Shane
Old 09-24-2006, 07:46 PM   #10
Member#: 67
1999 Outlasting
the competition.
send me some for the hondaroid
tom@kartboy is offline   Reply With Quote
Old 09-25-2006, 12:39 PM   #11
PARANOID56
Member#: 22035
2003 Brocoma DCab
sure, buy them from www.superbrightleds.com :P
Old 09-25-2006, 01:35 PM   #12
Member#: 67
1999 Outlasting
the competition.
*unabomberstyle* Aww Come on, i thought we were friends *unabomberstyle*
Old 09-25-2006, 04:31 PM   #13
PARANOID56
Member#: 22035
2003 Brocoma DCab
haha, maybe. but its for a honduh. i dont thenk LEDs work on those cars
Old 09-25-2006, 04:52 PM   #14
Handsdown
Member#: 29355
did you also replace your highbeam bulb?
Old 09-25-2006, 05:16 PM   #15
bildon
Member#: 59347
2006 WRX TR
with those new lights you better get a plate on there now man.
bildon is offline   Reply With Quote
Old 09-25-2006, 05:46 PM   #16
PARANOID56
Member#: 22035
2003 Brocoma DCab
ha, yea. i will get that plate on there soon. its only been like 6 months since i got it
no, no highbeam bulb replacemtn yet. i am working on makign a custom headligh harness first, them maybe some new bulbs.
Shane
Old 09-25-2006, 06:42 PM   #17
Handsdown
Member#: 29355
sounds good. i know the 9005 headlights can use a modified HIR bulb(the kind that come on vipers), i was wondering if you were going to do that.
Old 09-25-2006, 07:49 PM   #18
PARANOID56
Member#: 22035
2003 Brocoma DCab
i am most likly doing a HID retrofit with hids as the high beams also. but am also making a light bar that will hold some extra lights.
Shane
Old 09-26-2006, 10:26 AM   #19
Bbasso
Member#: 66235
2005 WRX
www.superbrightleds Are not as bright as standard bulbs.
My friend in his E350 van wanted brighter lights all around, so I told him about superbrightleds and he placed an order ($175). Two days later, he was calling me to bitch about the light sucking big time. I had to see for myself and was shocked. We double checked all the part numbers and were the the correct bright ones.
Never again will I try LEDs and most certainly him.
Bbasso is offline   Reply With Quote
Old 09-26-2006, 05:15 PM   #20
Zalthras
Member#: 102022
2006 wrb WRX
1987 panda FX16
Actually, they're just as bright as stock bulbs in certain applications. You have to note that the SMD LEDs without lens assemblies, the light output is only at a 170 degree arc, where a bulb is more like 345 degrees. So if the 194 bulb you're replacing relies on reflectors behind or to the side of the bulb, then the SMD LED will not work for your application without using those $30+ types that have the lenses (PIAA, BiJunon, Raybrig, etc). But, if you're replacing a bulb that only uses the outward projecting and limited sides angles (like the license plate lights on the Impreza), then the SMD LED is just as bright, if not clearer than a regular 194 bulb. And when compared to a 168 bulb,... it's alot brighter.
More pics:
The bulbs on my RX330and other reference for SMD LED 194s with lenses
click for a larger view of comparison between bulb and SMD LED
Zalthras is offline   Reply With Quote
Old 09-26-2006, 07:15 PM   #21
PARANOID56
Member#: 22035
2003 Brocoma DCab
hmm. I would guess that you didnt do your homework before buying LEDs . Mine are way brighter then stock bulbs. The only one that was bad was the dome light, and i am redoing that.
Shane
Old 09-28-2006, 12:51 PM   #22
AbACUZ
Member#: 101898
1905 NINETWO EX AIRO
Prodriv.Hotchkis.Stromng.
i think he was saying that his tail lights are not as bright ,, do they have SMD LED for the Tail light bulbs ???
AbACUZ is offline   Reply With Quote
Old 09-28-2006, 01:17 PM   #23
PARANOID56
Member#: 22035
2003 Brocoma DCab
They do have some that are brighter then bulbs now. but as posted above, it depends on how the reflecter is set up. They have some new 3w LEDs that are mega bright.
Shane
Old 09-28-2006, 01:21 PM   #24
Rapid_Roo
Member#: 31511
03 GD2 95 GM4
www.ITNRally.org
White High Power
slick. good timing too, one of my parking lights went out. guess its time to upgrade
Old 09-28-2006, 01:31 PM   #25
LastResort
Member#: 99289
What was the cost to do the full ting?
LastResort is offline   Reply With Quote
Trying to find Cigarette Lighter Adapter with LED Switches...HELP! P-Tein Interior & Exterior Modification 13 01-09-2009 03:27 AM
Does COBB for the 07 deals with the OL/CL delay issue? BBBsti LTD AccessPort 4 09-07-2007 08:54 PM
Please help with the OL/CL delay problem accelguy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 05-09-2006 04:26 AM
Ughhh bad day at the ol ranch nick9871 General Community 12 02-19-2006 10:44 PM
Can I use an LED switch for XEDE map switch? djoye Electrical & Lighting 0 09-02-2005 04:30 PM
