Old 07-19-2008, 10:06 PM   #1
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
Default #4 rod bearing is toast
Been reading for a while, thought I'd share. About a year ago, I'd hear a rattling at certain rpm/throttle, thought it was my skid plate hitting the headers. Once I got around to taking it off, my rattling didn't stop. It wasn't much at first, just annoying. After a few months it would get worse, happen upon startup for about half a second, then go away until about 3K rpms where it would come back under certain loads.
Fast forward to october 07 and it would get to the point of rattling at idle, but only when warmed up. So I finally figured it out and built up a spare short block and swapped it out last weekend. Here is the aftermath:
all other bearings look fine and normal wear for 90K miles, but #4 was the culprit. I chalk it up to abuse, autox, rallyx, and possible low oil due to waiting too long between changes. Either way, new block sounds fine after 100 miles and 1st oil change, I'll try to take better care of this one. This bearing lasted about 10K miles.
Old 07-21-2008, 06:39 PM   #2
gen_pete
Member#: 180948
2008 Impreza 2.5i
Obsidian Black Pearl
well there's your problem!!
gen_pete is offline   Reply With Quote
Stock rod bearing - What metals is it composed of? Bochet Built Motor Discussion 0 06-22-2009 05:02 PM
fs: 04 wrx shortblock bad #4 rod bearing needawrx13 NESIC Private Classifieds 10 03-25-2009 07:27 PM
what is? how does? spun rod bearing and threw a rod????? Mike7 Newbies & FAQs 5 01-27-2009 09:22 PM
If I spun a rod bearing on hybrid setup - buy upgraded rod bearings? MarylandEcstasy Built Motor Discussion 4 05-20-2007 12:54 PM
Rod bearing is probably toast, what did it wreck? Brighton Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 03-25-2007 07:34 PM
