#1 | |
Member#: 177805
Vehicle:2007 WRX Black |
Hi all.
I want to relocate my factory o2 wire. OEM exhaust position was before the mid cat as illustrated in the pic below Now I have a new Turboxs TBE but I have welded a bung before and after the cat. I want to put the OEM o2 sensor after the cat and my zietronix wideband sensor before the cat. I think the OEM o2 sensor operates 0v-1v. will it just be an easy splice and solder job ? I was advised to use crimp terminals. anyone have any advice or experience to offer ? here was the instructions (it was also to aid in avoiding the a CEL that appears when a new TBE is installed on an 06 wrx Quote:
#2 |
Member#: 177805
bump?
#3 |
Member#: 72234
South East
Vehicle:2004 WRX SRR EJ257-35R-6MT |
DO not cut or splice 02 sensor wires. You will make a poor decision by doing so. If you must extend 02 wires, buy a kit that plugs the harnesses. By all means do not cut and splice them even if you use solder.
| Thread Tools | |
| Display Modes | |
| Extending the MAF wires | NSFW | Electrical & Lighting | 13 | 05-20-2010 12:43 PM |
| Any drawbacks to extending o2 wires? | mdungelman | Electrical & Lighting | 5 | 10-05-2008 07:38 PM |
| Need extended Defi meter wire | shemoves | SWIC Private Classifieds | 5 | 06-30-2008 11:39 PM |
| Rear O2 Wiring Extension? | bhodson | Factory 2.5L Turbo Powertrain | 2 | 04-21-2004 08:25 AM |
| o2 wiring | bcristea | Factory 2.0L Turbo Powertrain | 2 | 06-01-2002 10:59 AM |
