Welcome to the North American Subaru Impreza Owners Club Monday October 24, 2016
Old 07-20-2008, 05:29 PM   #1
Member#: 53651
Cert Suby tech
specialist for hire!
Question Humming from fuse box
Well I have been trying to get my car to start and my fuel pump wont start and my starter will not turn or even make a noise. However I do hear a sort of humming from the fuse box in the engine bay. I have heard of those fuses that slowly burn out, not sure of their name though. Also is there a fuse for the fuel pump? If so where is this fuse? Im going to try direcly applying power to the pump to see if it will work. Help would be much appreciated. Ill go see which fuse seems to be "humming"
shadymilkman129 is offline   Reply With Quote
Old 07-21-2008, 10:40 AM   #2
Member#: 53443
2001 LL Bean Outback
The sound you are hearing is most likely a relay located in the power panel and it appears there may be a problem with the circuit that it is tied to. I assume the battery is fully charged so that isn't a problem and the cable connections have been cleaned. I would first see why the starter isn't working along with checking all the fuses in the dash and under the hood, for any problems.
building a fuse box, what fuses for what?? traction issuez Electrical & Lighting 3 05-27-2009 11:42 PM
crackle noise from fuse box subaru0276 Newbies & FAQs 3 02-29-2008 02:22 PM
Installing SW1- Power From Fuse Box... The Motel Fella Car Audio, Video & Security 2 05-04-2007 10:22 AM
Snorkel removed, humming sound coming from air box...? fastenova Legacy Forum 8 06-28-2003 12:02 PM
Humming from the intake. Apexboy Legacy Forum 14 09-15-2001 04:01 PM
