Old 07-20-2008, 09:48 PM   #1
RA Limited
Member#: 171249
2009 Chaco Z1 flip
Black/Blue
Default 20G block, 25D crank, 207 heads
Will this work? haha
I am 99% sure i have a closed-deck 20G lined up for cheap. I would like to use my 207 heads on it (so a 20G headgasket set is in order). I can use a phase 1 2.5L crank, right? If i do this, which thrust/man/rod bearings will i need? Are they the same on the phase 1 motors?
Would i want to use 20G pistons and rods? Do all the 2.0's use the same pistons? This is my first "build", so i'm a complet noob to it.
I'll probably be limping it around carefully at first, at least until i get a Power FC to tune it with.
Any other issues i should consider?
Anybody have a 2.5L crank for sale?
Thanks for any help on this.
RA Limited is offline   Reply With Quote
Old 07-20-2008, 10:05 PM   #2
keirnna
Member#: 50167
1996 Subaru STI RA
Wow, way not to include much information you noob ! Of course the EJ25D pistons won't work in the EJ20G block.
What he wants to do is use a EJ25D Phase 1 crank in his Phase 1 EJ20G block to make a bit of a stroker motor. Obviously he would need pistons and rods to really increase the displacement, but wouldn't the 25 crank bring the car closer to a square bore and stroke, although not much...
keirnna is offline   Reply With Quote
Old 07-20-2008, 10:11 PM   #3
RA Limited
Member#: 171249
2009 Chaco Z1 flip
Black/Blue
Would phase 2 rods even work on a phase 1 crank?
Old 07-20-2008, 10:20 PM   #4
keirnna
Member#: 50167
1996 Subaru STI RA
I don't think so, the main difference that I know of between phase 1 and phase 2 engines is the placement of the thrust bearing.
Comp. Ratio of EJ20G block, 207 heads RA Limited Subaru Conversions 4 06-23-2008 09:42 AM
Comp. Ratio of EJ20G block, 207 heads RA Limited Pre-2002 Factory Turbo Powertrain 2 06-22-2008 11:44 PM
lgt block with crank, and heads SAMSNEED Engine/Power/Exhaust 6 03-04-2007 03:35 AM
FS: JDM V7 Heads/V8 Valvetrain, Raw EJ22T block & crank, other random stuff jpmarotta Private 'For Sale' Classifieds 17 04-22-2005 12:21 PM
FS local: JDM V7 Heads/V8 Valvetrain, Raw EJ22T block & crank, other random stuff jpmarotta New England Impreza Club Forum -- NESIC 8 04-21-2005 08:01 PM
