Old 07-21-2008, 09:49 AM   #1
S1MPSONS
Member#: 90357
2006 Corey's EVO
& 1993 Mazda RX7
Default Tail Light Fuse Keeps Blowing. Help Please.
Hey Guys,
My rear tail light fuse keeps blowing and I don't know why. I change it to a new 10amp fuse every couple of weeks and sure enough it dies.
Is there a safe and reasonable fix for this? Perhaps running a different fuse amperage. Are there any other lights or electronics connected to the circuit I could investigate?
Any help would be greatly appreciated.
S1MPSONS is offline   Reply With Quote
Old 07-21-2008, 12:02 PM   #2
wrxskier18
Member#: 88005
2002 WRX PSM
GS500
Have you ever messed with the tail light before for wiring harnesses or the "JDM" mod?
could be a bad ground or something. Try taking the lamp off and checking connections. Do you know how to use a multimeter?
wrxskier18 is offline   Reply With Quote
Old 07-21-2008, 12:30 PM   #3
S1MPSONS
Member#: 90357
2006 Corey's EVO
& 1993 Mazda RX7
I have a cheap multimeter (or volt meter no sure) that I don't really know how to use. What do I do
I know I have a loose ground under the i/c that is supposed to be grounded to the top of the trans housing. I'll fix that and see if that works.
Old 07-21-2008, 12:50 PM   #4
ekw
Member#: 92141
2004 WRB STi TiC,RCE
Kartboy &Cobb-Jorge tuned
do NOT replace it w/ a higher rated fuse.
that fuse may be all that is keeping wiring from burning if you are getting an intermittant dead short.
possibly due to worn insulation, bare or loose wire, etc.
EDIT- (add)
you may do better if this thread gets moved to lighting & electrical.
the gurus there may be able to help you isolate what is on that circuit.
ekw is offline   Reply With Quote
Old 07-21-2008, 02:27 PM   #5
105wrx
Member#: 75931
2005 hmmm STI?
Clark Tuned!
Might want to check and see if there is any condensation in the lamp that is creating the short....
105wrx is offline   Reply With Quote
Old 07-21-2008, 07:50 PM   #6
thunder_lizard_1976
Member#: 145642
2007 WRX Ltd
Cuz Chicks Dig The Wagon
I recently found on another vehicle, that someone had modified the rear lights.. and the wires themselves were rubbing through/ shorting out on the frame/ body mounts, and blowing the fuses.. Start at the end of the circuit and work your way up..
It might take a while.. but go slowly, and you'll find the problem...
Patience is a virtue... for everything else... there's beer.....
thunder_lizard_1976 is offline   Reply With Quote
Old 07-22-2008, 01:15 AM   #7
S1MPSONS
Member#: 90357
2006 Corey's EVO
& 1993 Mazda RX7
There more than likely is moisture in the housing. Is this really a possible cause?
Old 07-22-2008, 01:59 AM   #8
S1MPSONS
Member#: 90357
2006 Corey's EVO
& 1993 Mazda RX7
Anyone else have any suggestions or can direct me to a how-to-use a multimeter page?
Old 07-22-2008, 12:04 PM   #9
wrxskier18
Member#: 88005
2002 WRX PSM
GS500
Old 07-23-2008, 09:10 AM   #10
S1MPSONS
Member#: 90357
2006 Corey's EVO
& 1993 Mazda RX7
Yay! Okay so how do I apply that to my rear tail light circuit? Right now, being that I just changed the fuse, everything is in working order. How will I be able to catch the problem with a multimeter? What should I be measuring? Where on the circuit should I be measuring?
Tail light fuse blowing out. fish4it38 Newbies & FAQs 1 11-16-2009 01:37 AM
Fog light fuse keeps blowing up bbun Electrical & Lighting 5 08-19-2008 06:51 PM
parking light fuse keeps blowing SCOOBIEdoo Electrical & Lighting 0 02-08-2007 11:41 PM
*Urgent* Wiring some lights and fuse keeps blowing Subwoofer87 Electrical & Lighting 6 09-20-2004 11:23 AM
Keep blowing tail light fuse- HELP... MK19 Electrical & Lighting 9 06-23-2003 01:06 AM
Message Board Statistics All times are GMT -4. The time now is 09:46 AM.
