Old 07-21-2008, 01:49 PM   #1
sxcobraz249
Member#: 123770
2006 WRX
Default Headlights no work!?!?!?....
I have had an H.I.D kit in my car for the last two years yesterday I went to turn on my headlights and they wont go on Everything else works my highbeams, city lights etc except my regular headlights what could it be. Because i know most of the symptoms to a bad ballast but that never happend and that wouldnt make both not turn on any help would be awesome...
p.s. could it be a relay and how could i find out??
sxcobraz249 is offline   Reply With Quote
Old 07-22-2008, 04:22 PM   #2
iFwrx
Member#: 180249
00 GC8
BRP
i have the same exact problem with my hids.. but only my right headlight doesn't work in low beams.. did u figure out what was wrong?
iFwrx is offline   Reply With Quote
Old 07-22-2008, 05:34 PM   #3
skingfreak
Member#: 152591
2010 Jetta TDI Cup
Jet Black
Did you check the fuse in your wire harness? and to check the relay you could take a positive wire directly from the battery to the positive on the ballast..(do at your own risk)
skingfreak is offline   Reply With Quote
Old 07-23-2008, 12:22 PM   #4
crasyboy412
Member#: 70840
2008 Subaru WRX STi
1. Check fuse
2. Check HID buld with another car
3. Check Ballast, it could that there water in there somehow, if it does,
them just bake it in the oven, and shake dry.
*3, was what happen to my HID, it work great now,
but I also order a 55K 5000K hid kit from lightwerkz,
hahahah
but good luck on your.
T
crasyboy412 is offline   Reply With Quote
02 wrx driver side headlight dont work,only works on high beam>>help! password:ej20 Electrical & Lighting 10 08-07-2008 02:33 PM
headlights no worky slickrex Electrical & Lighting 10 12-05-2006 06:21 PM
left turn signal no work when headlights are on Chuck the swimmer Electrical & Lighting 1 07-05-2006 09:19 AM
No days off left and no work to do makes Cole something something Cole Off-Topic 7 12-29-2005 07:05 PM
I have officially done no work at work today... RATyson Off-Topic 17 05-20-2004 09:23 PM
