Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine/Power/Exhaust
Closed Thread
Old 07-21-2008, 07:13 PM   #1
DS1
Vendor
Vendor Sales Rating: (17)
Member#: 111780
Default DS1 Is A Fully Authorized Tomei Dealer and Installer. Full Subaru Line Available!!!
We at DS1 Motorsports and Development are proud to announce that we are official Tomei dealers and installer. We carry the full range of Tomei's products for the Subaru and try to keep as much of it in stock as we can (this stuff moves quick). This also means that buying from an authorized dealer includes the 1-Year warranty from Tomei. The research and design that Tomei puts into all of their products is unparalleled anywhere in the aftermarket community. All of their trials for the EJ series engines are published on their website here. Here are a few of our featured products with tons of pictures.
Tomei 4-2-1 Equal Length Exhaust Manifold W/ Up-Pipe $990.00
Big Primaries and Huge Up-pipe!!! This is the best flowing header we have ever seen. All the flanges are hand ported and gasket matched. Then they are machined flat to provide a perfect seal. A three-bolt flange is used to further improve sealing at the up-pipe. All of Tomei's headers include all factory gaskets, hardware and header wrap w/ ties. It is the prefect complete bolt-on kit.
__________________
THE Biggest Motul Dealer in the Midwest, we can beat anyone's pricing!
[B][U][COLOR="Black"][FONT="Century Gothic"]"Your attempt to copy shows you have nothing to offer"[/FONT][/COLOR][/U][/B]
DS1 is offline
Old 07-21-2008, 07:14 PM   #2
DS1
Vendor
Member#: 111780
Tomei Twin-Scroll Equal Length Exhaust Manifold W/ Up-Pipe $970.00
Tomei didn’t only focus on the pipes diameter but also the design layout for the exhaust manifold. By reducing the sharp curves (at the gathering section) & long straight sections, helps minimize exhaust resistance & to increase the exhaust efficiency at higher RPM ranges. All the flanges are hand ported and gasket matched. Then they are machined flat to provide a perfect seal. A three-bolt flange is used to further improve sealing at the up-pipe. All of Tomei's headers include all factory gaskets, hardware and header wrap w/ ties. It is the prefect upgrade to a factory set-up.
Tomei ARMS M-7760 Bolt-On Turbo $1780.00
The ARMS-M7760 turbocharger was chosen because its size and dimension allows it to be swapped out in place of the stock turbo placement. Increasing turbocharger size usually hinders throttle response, however we have avoided this issue without sacrificing this aspect. This was made possible by carefully selecting the most ideal combination of components. As usual Tomei's kit includes all factory gaskets and necessary hardware. A bigger turbo without the lag, what more could you want?
__________________
DS1 is offline
Old 07-21-2008, 07:14 PM   #3
DS1
Vendor
Member#: 111780
Tomei Poncam 252-252 Camshafts $1440.00
The Poncam 252-252's are designed to maximize the stock port size and improve drivablilty. Since the AVCS function is present, A great amount of duration is not necessary. Of the four variations Tomei tested, the 252-252 shared same qualities as stock at the lower RPM range. As 5,200RPM as the boundary, some major power improvements were exhibited. These are hands-down the best cams you can get for stock internals.
Tomei Oil Pan Baffle/ Stiffener $390.00
One of the main causes of engine problems on an EJ20 are the bearings. The majority of the causes of these issues are due to the lack of motor oil in the oil pan (sump) and passages. Also, the lack of rigidity in the crank case is also another problem facing this engine design. Under extensive research, Tomei decided to develop a product that securely remedies these problems. This baffle stiffener will help strengthen the left and right side of the crankcase to help provide the added support with its dual structural design. The baffle design greatly aids the regulation of the oil supply.
__________________
DS1 is offline
Old 07-21-2008, 07:14 PM   #4
DS1
Vendor
Member#: 111780
Tomei Timing Belt Guide $50.00
Tomei Powered has constructed a beefy belt guide cut straight from aluminum with an extended length to securely apply more tension to the timing belt. This product comes in handy when immediate changes in torque are experienced by the engine, eliminating belt whip. The Anodized surface creates a smooth and precise belt track as well.
Also avaliable:
-Poncam EJ20 Type A (250-256) & Type B (256-264) $1590.00
-Individual Throttle Body System (Special Order) $8010.00
-Kevlar Timing Belt $210.00
-Headgaskets for EJ20 (Various Thicknesses) $380.00
-Headgaskets for EJ25 (Various Thicknesses) $400.00
-Bery-Rings IN/EX Set (Valve Seats) $520.00
-Valve Spring Set $310.00
-4-1 Unequal Length Exhaust Manifold w/ Up-Pipe $800.00
-Down-Pipe w/ Cat (JDM Length) $1050.00
-Down-Pipe w/o Cat (JDM Length) $520.00
Coming Soon:
Full write up on an '07 WRX TR w/ 4-2-1 Exhaust manifold, Poncam 252-252 and Arms M-7760 Turbocharger. On a base map made 340 HP and 371 Ft. Lbs. On pump gas.
Thanks,
The DS1 Crew
__________________
DS1 is offline
Old 07-21-2008, 10:41 PM   #5
anthonywrx
Member Sales Rating: (19)
Member#: 60276
2012 Chevy Malibu LT
03 WRX/STi hybrid sold :(
Dylan that turbo makes me feel all tingly
anthonywrx is offline
Old 07-21-2008, 11:21 PM   #6
RedRoobyScooby
Member Sales Rating: (5)
Member#: 110699
Pearl Red
yes! you fixed the site!!!!
RedRoobyScooby is offline
Old 07-22-2008, 12:17 AM   #7
sopmoney
Member Sales Rating: (14)
Member#: 146031
03 tomei ftw!
psm
back to your cave dylan! i ordered 1 of everything
sopmoney is offline
Old 07-22-2008, 06:30 PM   #8
DS1
Vendor
Member#: 111780
All Pm's Replied.
Ive got more stuff coming in on Monday.
__________________
DS1 is offline
Old 07-23-2008, 04:47 PM   #9
DS1
Vendor
Member#: 111780
Bump!!
__________________
DS1 is offline
Old 07-24-2008, 03:10 PM   #10
DS1
Vendor
Member#: 111780
Check us out on Tomei's site listed here as "Subaru Specialist"
__________________
DS1 is offline
Old 07-25-2008, 01:08 AM   #11
sopmoney
Member#: 146031
03 tomei ftw!
psm
man, do i get a t-shirt or maybe some sorta perk for that 11.5k i dropped? lol! cant wait!
sopmoney is offline
Old 07-25-2008, 02:59 AM   #12
DS1
Vendor
Member#: 111780
^^ they only make them in small Asian sizes (aka none for me either)
__________________
DS1 is offline
Old 07-25-2008, 10:50 AM   #13
sopmoney
Member#: 146031
03 tomei ftw!
psm
ok thats it im going on a diet! ok never mind
sopmoney is offline
Old 07-25-2008, 03:07 PM   #14
DS1
Vendor
Member#: 111780
Pms Replied
__________________
DS1 is offline
Old 07-26-2008, 12:58 PM   #15
DS1
Vendor
Member#: 111780
bump!
__________________
DS1 is offline
Old 07-28-2008, 01:42 PM   #16
DS1
Vendor
Member#: 111780
More parts arrived today!! Pics coming soon.
__________________
DS1 is offline
Old 07-29-2008, 01:28 PM   #17
DS1
Vendor
Member#: 111780
Timing belt guide pic's added and in stock.
__________________
DS1 is offline
Old 07-29-2008, 06:43 PM   #18
DS1
Vendor
Member#: 111780
All Pms replied!!
__________________
DS1 is offline
Old 07-29-2008, 09:02 PM   #19
Brody8877
Member#: 92355
2013 Impreza 2.0i
Ice Silver
is the tomei cams for STi models only or can it be use for 06-07 wrx?
Brody8877 is offline
Old 07-29-2008, 11:56 PM   #20
DS1
Vendor
Member#: 111780
Both
__________________
DS1 is offline
Old 07-30-2008, 01:28 AM   #21
schuey_1
Member Sales Rating: (3)
Member#: 72524
05 Subaru WRX Sti
If i get the Arms M-7760 Turbocharger do i need to change my injector and fuel pump ?I have a 05 STi.
Thanks
RJ
schuey_1 is offline
Old 07-30-2008, 11:25 AM   #22
DS1
Vendor
Member#: 111780
Yes you would need a lager set of injectors and a good pump.
We have PE injectors and Denso 280lph pumps in stock.
__________________
DS1 is offline
Old 07-30-2008, 06:08 PM   #23
DS1
Vendor
Member#: 111780
Pms Replied
__________________
DS1 is offline
Old 08-01-2008, 12:32 PM   #24
DS1
Vendor
Member#: 111780
1 Timing guide left till our next shipment!
__________________
DS1 is offline
Old 08-01-2008, 09:47 PM   #25
DS1
Vendor
Member#: 111780
4 more turbos in transit!!!
__________________
DS1 is offline
Closed Thread
AMS is now an Authorized Whiteline dealer! AMS MWSOC Vendor Classifieds 7 03-15-2007 05:13 PM
