Welcome to the North American Subaru Impreza Owners Club Saturday August 1, 2015
Old 07-21-2008, 09:51 PM   #1
jstam
Member#: 103489
2003 WRX
Undetermined
Unhappy Camshafts a waste?
hey guys...im 83% done with my bueye build! haha i got the heads on but im still debating on if i should stay with the stock cams or go with the BC Stage 2 272's. a ford guy i work with said that since i got a bigger turbo and will be boosting more, cams that big wont benefit me. he also said since i had some p&p done to the heads i really dont need them...anyone that knows something about the subaru world that could help would be aawesome. thanks again guys.
jstam is offline   Reply With Quote
Old 07-21-2008, 09:59 PM   #2
Chocoholic005
Member#: 179736
2005 Legacy GT
RBP
Cams are the brains of the engine, choose the wrong ones and it won't be worth it, but if you do your research, factoring in what your goals are they are totally worth it.
Chocoholic005 is offline   Reply With Quote
Old 07-22-2008, 12:15 AM   #3
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
Originally Posted by WJM View Post
Wisdom is present in this post.
To the OP: PLEASE do some SERIOUS research in the matter. There are TONS of cams out there. Most of them do nothing. A lot of them you get zero gains, some losses and then crappy driveability.
Since someone will ask...I dont have a real cam preference, but from what I've see, the GSC cams seem to be doing quite well on various builds.
wisdom is present in this post also..
I can't stress enough the side effects of some of the more aggressive cams on daily driveability. Many things we take for granted with the stock setup (ex. being able to follow a low speed limit in town without the engine bucking and stumbling all over the place because it has now become useless at around 2500 rpms and below), idling with an AF ratio that will quickly kill off your cats, and if you are catless, draw attention to the catless nature of your car since it has to idle so rich in order to stay running, and the list goes on. Oh, and let's not forget the inability to cruise at anything close to 14.7:1, meaning embarrassing gas mileage on the highway.
Guess how I know all of this...
jigga is offline   Reply With Quote
Old 07-22-2008, 11:11 AM   #4
bluescoobywagon
Member#: 14911
Not A Wagon!
2011 WRX - 285s on 18x9.5
Sooo.... how big ARE your cams?
bluescoobywagon is offline   Reply With Quote
Old 07-22-2008, 11:13 AM   #5
jays05
Member#: 78165
05 STI 35r + e85
Wow, to some extent I experienced every side-effect of aftermarket cams that Jigga mentioned.
jays05 is offline   Reply With Quote
Old 07-22-2008, 02:21 PM   #6
subiefast
Member#: 184150
wrx 6265 turbo
8000 rpm built EJ257
I'm running 272 cams. Drivability is still good.
subiefast is offline   Reply With Quote
Old 07-22-2008, 03:04 PM   #7
9vapors
Member#: 92582
280/280... looking forward to that...
9vapors is offline   Reply With Quote
Old 07-22-2008, 07:01 PM   #8
charliew
Member#: 125304
Wittmer25 is running bigger cams than 272 I think, and his car runs very politely on the street other than the sound of the exhaust. I don't know that there is such a thing as gas mileage if you want power. I would rather have the power of a turbo 2.5 than the na power of a 350 chev for the gas mileage. BB chevs making 450 hp don't have any gas mileage.
You just gotta forget about the big motor low end torque.
charliew is offline   Reply With Quote
Old 07-22-2008, 07:08 PM   #9
Turbo_Mike
Member#: 130276
2004 Pontiac GTO
LS1 T56 RWD
hmm thats interesting.. I run BC 272 cams and it runs damn good..
Anything above 1600 it doesnt buck, I run 14.9:1 AFR on the highway and get decent mileage(21-23 depending on my mood), and it runs great.... but then again I tuned my car and I know what I'm doing... that has a lot to do with it
Turbo_Mike is offline   Reply With Quote
Old 07-22-2008, 09:37 PM   #10
LiquidForce
Member#: 12811
2002 2.5l Wrx
517whp/516wtq (Stage pi)
Can you guess which is with upgraded cams and which one is stock?
LiquidForce is offline   Reply With Quote
Old 07-23-2008, 04:43 AM   #11
bugeyes
Member#: 64494
2001 V7 sti
Very similar situation......
I'm running slightly larger than 272.
Standard open loop tune for highway 14.7 and closed loop control at 15.5. I get good economy (up to the mid 20's).
Yes there is some low rpm power loss which is only evident when starting off from stationary, once going is not noticeable (my ceramic clutch makes this worse, I'd say with a standard type clutch it would be much more drivable).
Typical idle speed 1100rpm.
But the power above 4000 to 8000 is something no standard cam is going to match.
If I was to build again I would go the same cams no doubt about it.
bugeyes is offline   Reply With Quote
closed subydude02 Engine/Power/Exhaust 41 08-11-2010 08:29 AM
times not wasted, when ur getting wasted SQ3.0dotJP Political Playground 15 07-27-2009 03:33 PM
waste gate DP... none waste gate UpPiPe...?? yub2da Newbies & FAQs 1 02-13-2006 04:44 PM
('93-'01) cobb camshafts? Krelkor Impreza Forum 4 06-08-2001 08:36 AM
Legacy Turbo Camshafts Trey Legacy Forum 6 08-27-2000 12:22 AM
