Canada Region Club
Go Back   NASIOC > NASIOC Regional Areas > Canada Region Forum
Old 03-07-2002, 11:27 AM   #1
jstobern
Member#: 1395
Default Rear Brakes
Well it turns out that I have to replace the rear rotors and brake pads at 62000km. When stock components need replacing I like upgrading them with something that might be better then the OEM component.
Does anyone have any suggestions for the rear rotors and brake pads?
Anyone tried out the KVR products?
Thanks,
Jens.
jstobern is offline   Reply With Quote
Old 03-07-2002, 12:49 PM   #2
jstobern
Member#: 1395
Default What is special about OEM rotors and pads
I just got a quote from Subaru on the OEM cost to replace these parts on a 2000 Impreza 2.5 RS. Here is the break down:
115.72 for a rear rotor
172.60 for a set of rear brake pads (OH MY GOD!)
Screw OEM. I'm getting the stuff from kvr.
Later,
Jens.
Old 03-07-2002, 02:17 PM   #3
goobie
Member#: 8273
2006 WRX Wagon
Default Holy Jeebaz!
Are OEM brake pads really that much??
That's nuts, Go aftermarket for sure!
goobie is offline   Reply With Quote
Old 03-07-2002, 02:50 PM   #4
Robin2
Member#: 390
2011 WRX sedan
Plasma Blue
You could go with Legacy rotors and pads....
These rotors are better (thicker and ventilated).....
The only thing required to do this mod is to buy the caliper braket (from the legacy)......
For OEM stuff, call Auto Parts Extra......
Are you doing the work yourself?
Robin
Robin2 is offline   Reply With Quote
Old 03-07-2002, 03:02 PM   #5
Robin2
Member#: 390
2011 WRX sedan
Plasma Blue
Here's the link.....
http://www.northursalia.com/m...s/vbrakes.html
Here's the parts required for the mod.....
26296AA082 Brake Pad Kit
26291AA100 Disk Brake Kit Rear Right
26291AA110 Disc Brake Kit Rear Left
26310AA112 Brake Disk Rear (need 2)
Here's the pic of both rotors.
Robin
Old 03-07-2002, 07:21 PM   #6
direwlf
Member#: 1479
1999 Impreza 2.5RS
Silverthorn Metallic
Hmmmm...Robin how hard is that conversion? Also, what does it do to the brake bias?
direwlf is offline   Reply With Quote
Old 03-07-2002, 10:35 PM   #7
markus
Member#: 438
2004 STi
White on Gold
Default Call PDM
PDM Racing
Don Nimi has the Brembo made KVR cross-drilled rotors to replace the stock ones and they look nice without having to source a bunch of other stuff.
Just swap out the rotors and put aftermarket pads in and you'll have better than OEM stopping power.
IIRC, if you have a MY99 or earlier, Don also has KVR pads. He tells me that SS brake lines are on the way.
markus is offline   Reply With Quote
Old 03-18-2002, 10:27 AM   #8
jstobern
Member#: 1395
Robin,
The legacy change over is pricey if you can not find the calipers used. Here is the brake down.
Brake pad kit: 114.74
Left & Right Calipers: 370.83 each
Left & Right Rotor: 100.39 each
At the same time might as well do the WRX front swap:
Left & Right Caliper adapter: 90.93 each
Left & Right Front Rotors: 175.59 each
All parts sourced locally.
Markus,
KVR is actually local to Ottawa. You can have ANY rotor slotted or drilled for 30 dollars and ANY rotor plated for 15 dollars.
Later,
Jens.
Old 03-18-2002, 12:34 PM   #9
Robin2
Member#: 390
2011 WRX sedan
Plasma Blue
Those are some crazy prices..... Is that dealer rates?
What did you pay for your parts at KVR?
Robin
FS - MD: - H6 / DBA rear brake upgrade & 04 WRX rear brakes MD04WRX Suspension/Brakes/Handling 10 03-20-2009 03:46 PM
2004 H6 rear brakes vs. '05+ Legacy GT rear brakes? Geoff Brakes, Steering & Suspension 6 03-04-2008 07:07 PM
FS SoCal: LGT front brakes, LGT rear brakes. Ver. 4 rear disc conversion (complete) DiscoWagon Suspension/Brakes/Handling 34 10-26-2006 04:46 PM
wrx rear brake convert to sti rear brake sonic rex 03 Brakes, Steering & Suspension 0 12-22-2005 08:29 PM
Front Brakes ---> Rear Brakes Extraze Brakes, Steering & Suspension 7 07-12-2002 10:35 AM
