Old 07-22-2008, 12:19 PM   #1
davedaman77
Member#: 177385
08 2.5i
SSM
Default Transmission/clutch Probs!
Okay, I recently upgraded my engine hp by strapping a stock TD04 on my ej18(and all the other expensive neccesary parts ). I'm now putting out stock WRX power! (about 175 when I had it dyno tuned.) Which I very, VERY happy with!
Now, the real problem that I'm facing is my clutch. It's just 100% not able to handle this HP increase. And it's no fun not getting to drive it the way it deserves to be.. Trashing civics!
Right now, I'm rolling the stock ej18 FWD tranny and with no aftermarket help, there's no where to go but up...grade! So, money issues dropped the idea of swapping in AWD. But, does anyone know more about the AWD tranny? Like is it spilt yolk? Would it be possible to swap in an AWD WRX tranny without hooking up a drive shaft and it run?
Someone have any advice? This might be a stupid question, but it sucks having some HP but no way to drive it.
Oh, another question: Does anyone know of a clutch that will fit despite what the description says? Like '93Impreza1.8T used a 2.5RS clutch in his 1.8 AWD tranny..
Anything helps!
davedaman77 is offline   Reply With Quote
Old 07-22-2008, 06:31 PM   #2
'93Impreza1.8T
Member#: 171092
1993 Impreza 1.8T
Anything helps!
yea i am using the rs clutch with a 2.2 flywheel the 1.8 flywheel is to small for the rs clutch but it all holds up great now and was a direct bolt-on after getting the flywheel good luck i also love the awd when i did the conversion i tried to run it with just the fron cv's installed and nothing connected to the rear and it wouldn't move. i have the open diffs. wich send more power to the slipping wheels.
'93Impreza1.8T is offline   Reply With Quote
Transmission/clutch Probs! davedaman77 Newbies & FAQs 2 07-22-2008 12:17 PM
Clutch probs wrx_wraith Transmission (AT/MT) & Driveline 7 02-03-2004 03:03 PM
What is the deal with the ABS/Clutch probs? jmaiken Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 05-10-2002 07:32 PM
Synchro prob or clutch prob? Evaider Transmission (AT/MT) & Driveline 4 03-19-2002 10:27 AM
clutch probs solved?!?! greg Mid West Subaru Owners Club Forum -- MWSOC 11 08-24-2000 10:20 PM
