Old 07-22-2008, 12:35 PM   #1
silverf0x
Member#: 147664
2015 WRX Limited
Default It shakes like crazy
Brand new
FK452 225/45/17 on 5Zigen ZR+ (17x8)
Balanced twice
Alignement done
Hub ring center installed
Pression 32/32
I never hit the sidewalk with the car nor been in an accident of any sort
My problem: when I go over 120km/h (75mph) my steering wheels starts to shakes like crazy. The driving is not affected per se.. it's just an unbearable shaking that increases with speed. Kinda like having ice stuck in the rim on winter..
I need solution fast, I'm lapping on Thursday
silverf0x is offline   Reply With Quote
Old 07-22-2008, 12:44 PM   #2
drivin blind
Member#: 73043
2011 STI/2010 370Z
Black/Black Cherry
Take them back and have them re-balanced. You may have thrown a weight. Did they do this from day one? Either way, take them back. RP
drivin blind is offline   Reply With Quote
Old 07-22-2008, 12:52 PM   #3
nhat
Member#: 140163
03 STi
hellaflunctional
my guess is whoever mounted your tires did a static balancing instead of dynamic. ask for a dynamic balancing of the tires.
Old 07-22-2008, 01:05 PM   #4
silverf0x
Member#: 147664
2015 WRX Limited
I bought them in May from Discount Tire Direct. They came already mounted & balanced.
They did that from day one.
So last week I had them re-balanced but my mechanic told me they were near perfect (only added small weigths lower than 0.7)
Old 07-22-2008, 01:53 PM   #5
nhat
Member#: 140163
03 STi
hellaflunctional
are all the weights on one side of wheel or on both halves?
Old 07-22-2008, 01:59 PM   #6
NickVu
Member#: 27525
03 wrx wagon
yellow
Swap the front wheels to the rear just to make sure it's the wheel/tires themselves and not other suspension problems like loose bushings, failing balljoints, etc.
NickVu is offline   Reply With Quote
Old 07-22-2008, 02:00 PM   #7
Rodwrx23
Member#: 170948
I'm having a similar issue with my front passenger wheel all of a sudden. Upon inspection, I found no missing weights and nothing wrong with the tire. I'm hoping it's not the wheel bearing going bad on me because I only have 45K miles.
Rodwrx23 is offline   Reply With Quote
Old 07-22-2008, 02:28 PM   #8
silverf0x
Member#: 147664
2015 WRX Limited
My mechanic, a well known Subaru tuner over here, told me the weights are perfectly placed.
I tried swapping back/front: didn't change anything
I upgraded both my sway bars + links (Whiteline all the way): didn't change anything
My car as only 30k.
Tonight I will swap with my other set (RE92a on JDM Legacy Spec B wheel) and test it out.
Old 07-22-2008, 02:33 PM   #9
nhat
Member#: 140163
03 STi
hellaflunctional
i've seen wheels that balance perfectly on a machine cause the steering wheel to shake at speed, due to the method of balancing. it happened to my gf's car when her wheels were statically balanced, as opposed to being dynamically balanced.
after 3 tries, we had our friend rebalance the wheels dynamically and all the shakes went away.
Old 07-22-2008, 04:39 PM   #10
Arctic Penguin
Member#: 119532
2006 WRX
find a shop with a 'road force' balance machine and have them re- done
Arctic Penguin is offline   Reply With Quote
It sounds like my tire is shaking SenorFartman Service & Maintenance 1 05-22-2007 04:58 PM
Car shakes like crazy after 85kpm/58mph! renda85 Brakes, Steering & Suspension 7 01-17-2007 04:25 PM
Tailgate rattles like crazy-SICK OF IT! ac30treb Interior & Exterior Modification 5 07-06-2006 04:24 PM
Shake it. Shake it like a polaroid picture. Charge Off-Topic 6 09-23-2003 11:01 AM
It just hailed like crazy and my baby survived! the_gille Mid West Subaru Owners Club Forum -- MWSOC 11 05-11-2001 12:54 AM
