Old 07-22-2008, 02:29 PM   #1
moonzie
Member#: 128537
2004 Baja Turbo
Red/Silver
Default A/C troubleshooting sensor issue
So I've got a 93 2.2 N/A Legacy wagon. The A/C used to work quite well on it but it's been acting up. Last night I started troubleshooting it.
It's got adequate freon in the system. All fuses look good. Plugged in the green connectors under the dash and did a voltage check - the compressor clutch is getting voltage while the car is looping through it's diagnostics, so I don't think it's a relay problem..
I did notice a few nights ago that the A/C finally decided to come on after I had been driving on the highway for a good hour or so (driving with A/C off). I had the windows down and decided to check it at a light. Heard the compressor engage, fans kicked on and it blew cold air. Turned it off and a few minutes later I tried it again and the compressor never came back on - blowing warm air.
When I turn on the A/C and it's not working, the fans also do not kick on. This leads me to believe that it's a problem with a pressure/temp sensor somewhere.
My only problem is now I don't have a DIY repair manual for this car. Suggestions? Help?
moonzie is offline   Reply With Quote
Old 07-23-2008, 01:05 PM   #2
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
Try jumpering the pressure switch that's on the receiver drier and see if things work.
Have you checked your system pressure with the car off to make sure you have enough pressure for the compressor to kick on?
Legacy777 is offline   Reply With Quote
Old 07-24-2008, 10:15 AM   #3
moonzie
Member#: 128537
2004 Baja Turbo
Red/Silver
Ahh thanks for the suggestion. I didn't know where the switch was! Will try that.
And yes, the car does have sufficient refrigerant in the system. At least on the high/low sides. Could be some sort of blockage... but I'm doubting that.
Old 07-24-2008, 01:24 PM   #4
moonzie
Member#: 128537
2004 Baja Turbo
Red/Silver
well I jumped the pressure switch (both circuits) and the fans kicked on steady, but still no compressor engage. I think the pressure switch is alright.
I've got a wiring diagram I'm looking over for the A/C unit, but I can't seem to locate the A/C cutout relay. Suggestions?
Old 07-25-2008, 11:37 AM   #5
Legacy777
Member#: 4800
Should be in the fuse box in the engine bay
http://www.surrealmirage.com/subaru/...location02.jpg
Troubleshooting diff issues talvai Transmission (AT/MT) & Driveline 0 10-06-2009 07:46 PM
Troubleshooting DCCD issues/ABS light Timdog1650 Transmission (AT/MT) & Driveline 2 02-16-2008 08:06 PM
Need help troubleshooting RSB issue AutoAviat Brakes, Steering & Suspension 6 09-18-2006 05:40 PM
Wire harness troubleshooting, known issues, points to check? overdose Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 12-01-2004 01:26 PM
Link Plus And TPS Sensor Issue seven881 Engine Management & Tuning 3 08-09-2004 12:42 AM
