Old 07-22-2008, 03:05 PM   #1
ellissti6
Member#: 170034
Default Who makes best adjustable cam gear
Does anyone know who makes the best adjustable cam gear? I have heard the jun ones are good, but what about obx they are about half the price but how reliable are they ? please comment
ellissti6 is offline   Reply With Quote
Old 07-22-2008, 04:28 PM   #2
modaddict
Member#: 95840
sold to a good bud
awaiting next car
define: best
modaddict is offline   Reply With Quote
Old 07-22-2008, 05:07 PM   #3
ellissti6
Member#: 170034
i say best as in most reliable and comparable to oem specification with regards to teeth design for the best, my main concern is having the belt jump timing, due to a faulty manufacturing process so just wondering if saving a few dollars on the obx gears are even worth it along with the ability to actually adjust and dial in the timing which would be easier to use or are they all the same?
Old 07-22-2008, 09:05 PM   #4
methaddict
Member#: 159738
2004 WRB STi
Full Race TS, BW 8374 EFR
I'm surprised AEM doesn't make one for Subaru.
methaddict is offline   Reply With Quote
Old 07-22-2008, 09:18 PM   #5
saintluciascooby
Member#: 109527
1997 GC8 [email protected]
blue
I have had the Jun, the CDB racing and a set of the Roger clark units.
my ranking.
#1 Roger clark titanium set $2500
#2 CDB racing #1300
#3 Jun ??? cant remember
#15 OBX
saintluciascooby is offline   Reply With Quote
Old 07-22-2008, 10:46 PM   #6
ellissti6
Member#: 170034
ok i see where you all are coming from i guess no sense in risking an important part like that on an obx brand
Old 07-22-2008, 11:10 PM   #7
gold rush
Member#: 90110
2004 wrx wagon
my ranking.
#2 CDB racing #1300
#15 OBX
CDB racing? Never seen these, do they make them for subys?
gold rush is offline   Reply With Quote
Old 07-23-2008, 08:10 AM   #8
ellissti6
Member#: 170034
but does anyone have any factual information as to why the parts are better also i mean i find some parts for jun highly over priced ie and oil pump for 1050 us ?
Old 07-23-2008, 08:55 AM   #9
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
IIRC Jun adjustable units start out life as OEM cam gears that they machine down and put an adjuster wheel on.
Old 07-23-2008, 11:42 AM   #10
methaddict
Member#: 159738
2004 WRB STi
I would like to see a metal replacement gear for the plastic ones. My mechanic broke one using the right tool and rounded off the allen bolt also.
Old 07-23-2008, 02:43 PM   #11
gold rush
Member#: 90110
2004 wrx wagon
Those plastic gears are a nightmare, even with the proper tool. But I think its because the bolt has a taper on the washer part that preloads it on. I had to drill mine out
Old 07-23-2008, 07:32 PM   #12
ellissti6
Member#: 170034
are the ajustable cam gears a nightmare? Is it better to get a set up drop in cams like kelfords?, im suppose to be going with a rigoli setup 272/272 with high lift but told it can only work with adjustable cam gears
Old 07-25-2008, 11:40 PM   #13
methaddict
Member#: 159738
2004 WRB STi
Can't we use metal gears of a 2.5 na motor to replace the plastic ones since there's no avcs on the exhaust cams?
Old 07-25-2008, 11:59 PM   #14
5iveLug_EK
Member#: 122278
2.5 is a sohc and i don't think they are the same.
5iveLug_EK is offline   Reply With Quote
Old 07-26-2008, 01:25 AM   #15
Splinter
Member#: 106510
98 Widebody 3.4L
Smooth Safety Blue
I have a set of metal gears... they came on my EJ20G
I used the USDM plastic gears tho, they're designed to fragment on impact to lessen the chance of catastrophic engine damage.
EDIT: Oh, you guys are talking about post-02 stuff... lol ignore me
Splinter is offline   Reply With Quote
Old 07-26-2008, 06:28 PM   #16
my99maddog
Member#: 55515
1998 MY99
Default Perfourmance Motor Sport
and the prettiest:
http://www.pms.net.au/03_performance.htm
Half the weight of the JUN items as well.
my99maddog is offline   Reply With Quote
Old 07-26-2008, 06:35 PM   #17
bertune
Member#: 107290
I have the OBX cam gears in my car and they are really nicely made, unfortunately you have to do a little sanding,filing and grinding but all in all they are worth it!
bertune is offline   Reply With Quote
Old 07-26-2008, 08:30 PM   #18
ellissti6
Member#: 170034
is it dangerous to use lighter adjustable cam gears? what would be the benefits other than faster acceleration would it be easier on the belt system ?
Old 07-27-2008, 01:53 AM   #19
sku81
Member#: 143283
2001 bugeye wrx
white
Originally Posted by my99maddog View Post
and the prettiest:
correct,I used to run JUN cam gears,worked grate but yes abit heavy so swaped to some PMS cam gears..also cheeper than JUN gears.
i cant find any pic's off my old JUN gears..sorry.
Kris
sku81 is offline   Reply With Quote
Old 07-27-2008, 02:15 AM   #20
methaddict
Member#: 159738
2004 WRB STi
Very nice. How much are they with our weak usd?
Old 07-27-2008, 06:28 AM   #21
sku81
Member#: 143283
2001 bugeye wrx
white
$990 AUD also no modding is needed,bolt on dial in and off u go.
Kris
Old 07-27-2008, 06:41 PM   #22
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
The '98 2.5RS, '98 Forester, '96-99 Legacy 2.5GT, and '97-99 Legacy Outback all came with N/A DOHC EJ25s. I don't know if the cam pulleys are interchangeable with the turbo DOHC engines, as I've never had them in my hands side-by-side.
Pat Olsen
Old 08-10-2009, 07:41 AM   #23
sku81
Member#: 143283
2001 bugeye wrx
white
some new adj cam gears i can get atm-
suit 99-00 sti or 99-02 wrx heads
half the weight off the JUN units(what ive also had b4) and slightly heave yer than my current PMS gears(there are stronger)
$850 inc gst + post
(JUN are $1200 trade) (old PMS are $990) the new 1's are cheaper and made to what robin wanted and no stuffing around with these 1's(much much better cam gears)
PM me if you want any sets.
Kris
Old 08-10-2009, 09:47 AM   #24
3MI Racing
Member#: 200987
I have a thread (Homemade WRX account) on the issues you'll find with fitting OBX gears.
3MI Racing is offline   Reply With Quote
Old 08-10-2009, 10:14 AM   #25
col5555
Member#: 142017
I have been told the biggest problem with most of the aftermarket cam gears is the anodizing of the aluminium on the toothed cog. It simply not hard enough and wears away and can result in the belt jumping.
col5555 is offline   Reply With Quote
2.5l DOHC Adjustable Cam gears - who makes them? acorreiajr Normally Aspirated with bolt-on Forced Induction Powertrain 20 10-31-2002 02:16 PM
Adjustable Cam gears for SOHC Jaxx Normally Aspirated Powertrain 12 09-15-2001 05:01 PM
Anyone use adjustable cam gears? Gerry Normally Aspirated Powertrain 7 10-25-2000 03:07 PM
Adjustable Cam Gears survey WRXGirl General Forum Archive 4 09-12-2000 07:39 PM
Subaru adjustable cam gears??!! Kyle Paton Technical Forum Archive 16 07-13-2000 12:52 AM
