Old 03-07-2002, 12:34 PM   #1
Jon Bogert
Member#: 1133
09 GTR, 02 996 C4S
95 993 C4, 71 911, 04 STI
Question Coilovers: where's the sweet spot?
I've been thinking about getting coilovers for the Scooby and I already have H&R coilovers on the Audi and I got to thinking:
Even though coilovers are height adjustable, they adjust the lower spring perch only. Therefore when you adjust the height, you're changing the static location of the piston in the strut. So, there will always be an "ideal" height from a performance standpoint, which is where there is equal (or some other ideal proportion) travel up and down. Any adjustment up or down takes the shock out of it's ideal range, much like putting lowering springs on a non-height-adjustable strut.
I guess this is why you have ridiculous situations such as DMS Golds not being able to run at stock ride height.
Now if you could actually adjust the rod length, effectively raising (or lowering) the whole strut assembly including the piston, as well as adjusting the lower spring seat, wouldn't that be much better? You would have a TRUE height adjustable suspension. Are there any coilovers that have this feature?
Or am I nuts.
Jon Bogert is offline   Reply With Quote
Old 03-07-2002, 01:13 PM   #2
RS2001
Member#: 3210
01 RS Coupe
05 WRX Wagon
Cuscos have it (adjustable casing).
-DAN
RS2001 is offline   Reply With Quote
Old 03-07-2002, 02:05 PM   #3
WagonMonster
Member#: 3781
2002 Legacy GT Wagon
2009 Forester X Limited
-DAN
Yeah, and for $2400 they better cook me breakfast too!
WagonMonster is offline   Reply With Quote
Old 03-07-2002, 03:52 PM   #4
slater
Member#: 5848
1992 vw corrado vr6
silver w/ schrick/quaife
zeal makes them as well. and if i remember correctly, they can be had for a LOT less than $2400! (like a little more than half that.)
zeal makes a great product.
slater is offline   Reply With Quote
Old 03-07-2002, 06:48 PM   #5
blkwag
Member#: 4838
2002 WRX Wagon
Black in Recovery...
You have to take into account that some struts are valved with linear dampening charactistics while others are valved for progressive dampening characteristics...
blkwag is offline   Reply With Quote
Old 03-07-2002, 07:25 PM   #6
RS2001
Member#: 3210
01 RS Coupe
05 WRX Wagon
Hey! He asked, I gave a solution, never said it would be a cheap one
-DAN
Old 03-07-2002, 08:34 PM   #7
ellisnc
Member#: 4229
2003 S2000
Did someone say track day
I really doubt you're going to care all that much unless you've got the car dumped which is stupid anyway or you've got it raised up for doing rally-x or whatever... in fact I don't even know that you have a problem when you raise them so take that for what it's worth
ellisnc is offline   Reply With Quote
Old 03-07-2002, 08:59 PM   #8
push2
Member#: 6531
Damn thats funny!!! Now only if they had more stuff for the wagons...
push2 is offline   Reply With Quote
Old 03-07-2002, 10:57 PM   #9
Jon Bogert
Member#: 1133
09 GTR, 02 996 C4S
OK, let's say you've got six good inches of travel without getting too close to topping out or bottoming out. Then you try to run stock ride height on coilovers optimized for 1.5" lower. So now you've only got 1.5" of "up" travel. What happens when you go over a rise? Not good! Topping out a strut is a no-no, just like bottoming it is. The wheel lifts off the ground, you hear a clunk, and all of a sudden you're dealing with air, when it should have just been a gentle crest.
This is my point. "Height adjustable" is a myth. You can tune and corner weight with 1/2" either way, but you'd be stupid to run at either extreme.
I'm realizing now that the answer is to call Dave Clark and tell him what ride height you want and give him your credit card number. Who cares about the rest when you can order exactly what you need?
Uh, where's the organic produce section again? (cnn link) edkwon Off-Topic 25 06-01-2010 09:23 PM
Where's a good spot to run wires through firewall!? yo14jman Car Audio, Video & Security 26 10-15-2007 10:28 AM
Gas Prices - Finding the sweet spot Trunk_Monkey General Community 2 04-12-2005 05:37 PM
The sweet, sweet nectar of the gods.... RokketRide Off-Topic 30 07-31-2004 05:37 PM
Where's a good spot to see the fireworks potenzaus Bay Area Impreza Club Forum -- BAIC 3 07-04-2003 10:05 PM
