Old 07-22-2008, 09:49 PM   #1
methaddict
Member#: 159738
2004 WRB STi
OFCD V3, FR TS, BW8374EFR
Default Interesting ring gap machine
I don't do engine builds myself to warrant buying one, but since they're local maybe they'll gap my rings for my build. I just like to know the measurements are spot on.
http://www.abs-products.com/specialt...grinder.shtml#
http://www.youtube.com/watch?v=RHSoSZvHoCo
methaddict is offline   Reply With Quote
Old 07-22-2008, 11:20 PM   #2
eastcoastbumps
Member#: 29201
BMW M3
Honda S2000x2
That is very trick. I like it, but I'm in the same boat. I don't do enough rebuilds to justify the nearly $900 price tag.
eastcoastbumps is offline   Reply With Quote
Old 07-23-2008, 04:21 PM   #3
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
When sizing your rings you should always use the proper tool to make sure the ring is cut smoothly and at the correct angle. You don't need a $900 ring grinder to do this properly however I could just see it know, go ahead and stick the ring in there, spin that baby up to 5,000 rpm, and oops I just took off 10 thousandths
I've seen some hack job hand filed rings and you really want to avoid that. You can get a decent ring grinder for a few hundred. When you start adding up what it costs to get all the proper tools sometimes it makes more sense to pay someone to do it but if you're brave and crafty go for it
Thanks,
Phil
www.elementtuning.com
Element Tuning is offline   Reply With Quote
JE 2618 Pistons Ring gap & valve notches... xbcaraudio Built Motor Discussion 4 04-17-2008 11:23 PM
ej20 arias .020 over pistons ring gap Scooby Rex Built Motor Discussion 5 07-31-2006 12:24 AM
ej20 arias .020 over pistons ring gap Scooby Rex Built Motor Discussion 1 07-26-2006 10:33 AM
2.2t ring gap TyranosaurusWRX Pre-2002 Factory Turbo Powertrain 8 04-19-2005 03:18 PM
Ring Gap Question Andursun0013 Normally Aspirated with bolt-on Forced Induction Powertrain 6 02-25-2005 03:02 AM
