Old 07-23-2008, 02:07 AM   #1
joekerk
Member#: 155250
Default AVCS better or non AVCS better for drag race
Hi bro, i am planning to upgrade my cams to cosworth 278 cams with MY04SPEC C head, wondering whether is AVCS a advantage to drag racing like 1/4mile drag or non-AVCS better on the high RPM.I also had Jun adjustable spocket . Which will be the best for beautiful power bend at high rpm.I will be using the TSR 70kit with a built engine. Heard from ppl avcs is very dangerous on high rev but if wan the best performance which will be better?
Any bro here can share it around before i go built my engine
joekerk is offline   Reply With Quote
Old 07-23-2008, 12:28 PM   #2
flycaster
Member#: 60142
2011 WRX
Grey
It's my understanding that AVCS was designed to help the bottom and middle end of the powerband, and by the higher rpms you're 100% "on the cam." In a full-on drag scenario, I can't see AVCS being any benefit whatsoever.
flycaster is offline   Reply With Quote
Old 07-23-2008, 12:30 PM   #3
blowbyu24
Member#: 84482
2005 STI.UR gt4088r
E85 pro comp sti
well it does help spool, so if the car will only ever be at the drag strip its not that necessary to have..but if your on the street and want that extra powerband and spool go with avcs
blowbyu24 is offline   Reply With Quote
Old 07-23-2008, 02:34 PM   #4
jays05
Member#: 78165
05 STI 35r + e85
Non-AVCS cams typically have more aggressive lobe profiles and more lift which would be better on the top-end.
jays05 is offline   Reply With Quote
Old 07-23-2008, 03:08 PM   #5
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
You can have both an AVCS cam and a non-AVCS cam with the same grind (valve clearance being the main concern but in either case you could have custom pistons made). The AVCS allows the cam timing to be altered which in effect can increase power up to about 5k rpm and in some cases beyond but that would have more to do with the centerline of the camshaft.
For road racing or street using AVCS is a huge asset and will allow larger turbochargers to have a wider powerband. Those who have motor swaps and switch to a Hydra EMS than can run AVCS are always happy and impressed with the gains. In drag racing since you'll be leaving the line with anti-lag or launch control and rpms will typically always be above 5K rpm it doesn't really offer any benefits but it really wont hurt you either.
My suggestion is just to pick a cam with a proven track record that you will not have to use adjustable cam gears for. Many AVCS cams are built with the intake cams retarded and use the AVCS to correct that for lower rpm power and then return to a retarded state for more top-end power. With that said I've tuned EVOs that have picked up 25 whp while tuning with adjustable cam gears. This can be time consuming and expensive since you'll have to pay someone like me to tune various settings along with the dyno time. The EVO cam sprockets are easy to reach and there are only two where the Subaru will need 4 to be adjusted and fans will be grinding away at your arms as you try to adjust them on the dyno
Thanks,
Phil
www.elementtuning.com
Element Tuning is offline   Reply With Quote
Old 07-23-2008, 11:20 PM   #6
joekerk
Member#: 155250
element tuning , u r very detail, right now i got 4 Jun adjustable spocket. I am planning to get the cosworth head and cams set to upgrade on my head works.
I am mainly looking for drag. So u advise is to carry on with the avcs or use stop the avcs and use the Jun adjustable spocket for it seems i actually have them.
Old 07-30-2008, 11:42 AM   #7
Element Tuning
Member#: 54918
673 WHP Element
I have made a ton of power with the JUN cams so if you have the time and money to dial in the cam sprockets I would say for drag racing, stick with it.
Thanks,
Phil
AVCS Heads on Non-AVCS blocks. readymix Built Motor Discussion 43 03-27-2009 10:30 PM
whats a better turbo for a 2.0 for drag racing 05blkwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 35 12-31-2006 12:58 AM
AVCS heads ---> non-AVCS use??? Peeblesmx445 Built Motor Discussion 14 03-19-2006 10:06 PM
Is stock wheel better for drag racing? wrx2 Proven Power Bragging 35 10-24-2003 12:23 PM
Question for drag racing, better for our cars to deep stage? Andrew Motorsports 11 04-16-2002 12:20 AM
