#1 |
Member#: 155250
Hi , i believe when we high rev a ej25 engine , the engine oil will spit out from the bittle , I heard is also do with the piston we used. some piston will try to mini the spit of the engine oil and had a longer service. Wat piston is very relieable for EJ25 engine.
#2 | |
Member#: 108965
Vehicle:2005 Subaru WRX STi |
#3 |
Member#: 155250
I am current using CP , if is ok i think to use back, i just hope to check with anyone who try before other piston which will not throw out so much engine oil
#4 |
Member#: 32669
SCIC
Vehicle:2007 FR TS EFR 7670 LINK G4 hybrid STi |
Sound like more than a piston problem and more like a breathing problem
#5 |
Member#: 155250
keke , i am a newbie ,of course we had to fixed the ring loose for high boost,but i also heard from workshop tat some time it depend on the brand of the piston too,just wondering how true
#6 |
Member#: 159738
SCIC
Vehicle:2004 WRB STi Full Race TS, BW 8374 EFR |
Let's talk about why a piston is better. Skirt design, off set pin boss, coated rings, etc.
#7 |
Member#: 155250
| Thread Tools | |
| Display Modes | |
| Cobb (JE) offset pistons - which way is up? | 1GR8WRX | Built Motor Discussion | 15 | 02-28-2008 06:41 PM |
| Tired of searching, Can someone tell me which cylinder is 1 and which is 4? | crowbar | Off-Topic | 4 | 10-24-2006 02:47 PM |
| which pistons and which clutch | sr55stiguy | Factory 2.5L Turbo Powertrain | 22 | 11-16-2005 10:24 PM |
| Which pistons for stock 2.0 block, wiseco or arias? | wrxracer55 | Factory 2.0L Turbo Powertrain | 36 | 06-14-2005 01:56 AM |
| Of that 3 plug bulb connector, which one is high, and which one is for low beam? | Kwyjibo | Electrical & Lighting | 1 | 10-21-2003 08:07 PM |
